NR2 Pro image number 0
POWER THAT DEFIES SIZE.
NR2 Pro
Experience exceptional computing performance in a small footprint with the NR2 Pro.
This system features up to a cutting-edge Intel Core i9-14900K processor and a powerful NVIDIA GeForce RTX 4080 Super graphics card, delivering outstanding gaming, productivity and content creation capabilities.
Engineered with Cooler Master's decades of thermal expertise, the iconic NR2 Pro ensures efficient cooling for maximum component performance and longevity.
EXPERIENCE STUNNING VISUALS IN DEMANDING WORKLOADS
The NR2 Pro Compact High Performance PC is designed to deliver exceptional 4K performance for visually demanding applications. Explore immersive creative projects, high-resolution contents, and the latest AAA games with outstanding visual fidelity.
EXCEPTIONAL PERFORMANCE
FOR WORK AND PLAY
The Intel i9-14900K delivers remarkable power with 24 cores (8 Performance, 16 Efficiency) and 32 threads. Its Max Turbo Frequency is up to 6GHz, ensuring smooth multitasking across demanding applications, content creation, and everyday computing.
IMMERSIVE GRAPHICS
AND NEXT-GEN FEATURES
The NVIDIA GeForce RTX 4080 Super delivers cutting-edge visuals, redefining what's possible in both gaming and creative workflows. Immerse yourself in stunning ray-traced environments and boost performance with AI-powered DLSS. The dedicated NVENC encoder ensures smooth and high-quality streaming so you can share your best moments effortlessly.
MAXIMIZE SYSTEM POTENTIAL WITH HIGH-SPEED MEMORY
Equipped with 64GB of high-speed DDR5-5600MHz memory, effortlessly juggle multiple applications, demanding games, and creative projects without compromise. Experience smooth and responsive performance that enables you to focus on the task at hand.
HIGH-PERFORMANCE STORAGE SOLUTION
The 2TB NVMe Gen 4 SSD delivers blazing-fast performance for games, creative workflows, and everyday use. Minimize load times and enjoy the freedom to store your game library, videos, and other large files without compromise.
SMALL FORM FACTOR, PRECISION COOLING & BIG PERFORMANCE
The NR2 Pro Compact High Performance PC features a 280mm Cooler Master AIO liquid cooler and a highly-advanced 3rd-generation CPU pump, ensuring efficient heat dissipation. Maintain optimal system temperatures for reliable and high performance computing under demanding workloads.
Buy Now for the ultimate performance boost
Upgrade your gaming experience with a full PC from Cooler Master!
Full PC
NR2 Pro i7/4060ti
B760i WIFI DDR5Intel Core i7-14700F280mm radiator, 2 x 140mm SickleFlow PWM,Gen 3 Cooler Master PumpGeForce RTX 4060 TI 8GBCooler Master NR200P Max32GB 2 x 16GB 6000MHz1 TB M.2 2280 PCIeCooler Master V850 SFX GoldWindows Home
Full PC
NR2 Pro i7/4070 Super
B760i WIFI DDR5Intel Core i7-14700F280mm radiator, 2 x 140mm SickleFlow PWM,Gen 3 Cooler Master PumpGeForce RTX 4070 Super 12GBCooler Master NR200P Max32GB 2 x 16GB 6000MHz1 TB M.2 2280 PCIeCooler Master V850 SFX GoldWindows Home
Full PC
NR2 Pro i7 / 4080 super
B760i WIFI DDR5
GeForce RTX 4080 Super - 32GB DDR5
Cooler Master NR2 Pro
32GB DDR5 6000MHz
1TB M.2 NVMe SSD
Windows 11
Full PC
NR2 Pro i9 / 4070TI Super
Z790I WIFI DDR5
GeForce RTX 4070 Ti Super
64GB of 5600 Hz DDR5 RAM
2 TB M.2 2280 PCIe
Windows Home
full PC
NR2 Pro i9/4080 Super
Z790I WIFI DDR5Intel Core i9-14900K280mm radiator, 2 x 140mm SickleFlow PWM,Gen 3 Cooler Master PumpGeForce RTX 4080 Super 16GBCooler Master NR200P Max64GB of 5600 Hz DDR5 RAM2 TB M.2 2280 PCIeCooler Master V850 SFX GoldWindows Home
