NCORE 100 MAX image number 0
NCORE 100 MAX image number 1
NCORE 100 MAX image number 2
NCORE 100 MAX image number 3
NCORE 100 MAX image number 4
NCORE 100 MAX image number 5
NCORE 100 MAX image number 6
NCORE 100 MAX image number 7
NCORE 100 MAX image number 8
NCORE 100 MAX image number 9
NCORE 100 MAX image number 10
NCORE 100 MAX image number 11
NCORE 100 MAX image number 12
NCORE 100 MAX image number 13
NCORE 100 MAX image number 14
NCORE 100 MAX image number 15
NCORE 100 MAX image number 16
NCORE 100 MAX image number 17
NCORE 100 MAX image number 18
NCORE 100 MAX image number 19
NCORE 100 MAX image number 20
NCORE 100 MAX image number 21
NCORE 100 MAX image number 22
NCORE 100 MAX image number 23
NCORE 100 MAX image number 24
NCORE 100 MAX image number 25
NCORE 100 MAX image number 26
NCORE 100 MAX image number 27
NCORE 100 MAX image number 28
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
NCORE 100 MAX
Max Performance, Minimalist Design
NCORE 100 MAX
Cooler Master’s NCORE 100 MAX is the ultimate solution for going big on performance in the minimal amount of desktop space
CUSTOM AIO COOLING
The NCORE 100 Max leverage decades of expertise in thermal solutions and features a custom 120mm AIO Water Cooler supporting the latest Intel and AMD CPUs.
GPU
HIGH-END GPU COMPATIBILITY
Includes support for high performance, triple-slot GPUs up to 336mm in length and 140mm in height, with four included 6+2 pin power cables and a vertical mount design.
Performance
TAILOR-MADE POWER SOLUTION
Cooler Master's V SFX Gold 850W ATX 3.0 PSU covers all your power needs and comes with custom length cables.
Design
ULTRA-SMALL FOOTPRINT
The NCORE 100 MAX is super compact, with a footprint about the size of a small booklet.
PREMIUM ALUMINUM PANEL
An anodized aluminum shell makes the NCORE 100 MAX stand out as a desktop work of art.
PRE-ROUTED CABLES
Includes custom length, pre-routed cables which have been placed right where you need them and are ready to be connected to your motherboard and GPU.
AIRFLOW
The NCORE 100 MAX layout has been meticulously
designed to offer the most efficient thermal layout.
This layout pulls in air from the standing sides of
the case, which are its largest surfaces.
OPEN FRAME DESIGN
Eliminating three surfaces usually included in a standard case to let
you approach installation from numerous angles. Even and cable cover
features tool-less removal, for the utmost in accessibility.
Tech Specs
SPECIFICATIONS & DOWNLOADS
  • Product Number NCORE 100 MAX: NR100-MNNN85-SL0, NR100-MNNN85-SL1
  • Product Number NCORE 100 MAX Bronze Edition: NR100-ZNNN85-SL0, NR100-ZNNN85-SL1
  • Exterior Color NCORE 100 MAX: Dark grey
  • Exterior Color NCORE 100 MAX Bronze Edition: Bronze
  • Materials - Exterior Steel, Plastic, Aluminum
  • Materials - Side Panel Aluminum
  • Dimensions (L x W x H) Normal mode: 155mm x 212mm x 481mm (Incl. Protrusions)
  • Dimensions (L x W x H) Expansion mode: 172mm x 212mm x 481mm (Incl. Protrusions)
  • Dimensions (L x W x H) 155mm x 212mm x 457mm (Excl. Protrusions)
  • Dimensions (L x W x H) 172mm x 212mm x 457mm (Excl. Protrusions)
  • Volume 15.80L (Normal mode)
  • Volume 17.54L (Expansion mode)
  • Motherboard Support ITX
  • Expansion Slots 3x PCIe Slot Mounting
  • Drive Bays - 2.5" SSD 1
  • I/O Panel 2x USB 3.2 Gen1 Type A
  • I/O Panel 1x USB 3.2 Gen2 x 2 Type C
  • I/O Panel 1x Audio Combo (Audio In / Out 3.5mm)
  • Pre-Installed Accessories 1x 240mm PCIe 4.0 x16
  • Pre-Installed CPU Cooling Solution 120mm Radiator with 38mm Thickness x 1 (Custom PWM Fan Max. 2400RPM)
  • Pre-installed Power Supply Unit V SFX Gold 850W ATX 3.0
  • Pre-installed Fan(s) - Rear 120mm SickleFlow PWM Fan x1 (Max. 1800RPM)
  • Clearances - CPU Cooler 48mm
  • Clearances - Power Supply 100mm
  • Clearances - RAM 48mm
  • Clearances - Graphics Card 337mm x 62mm x 180mm (Normal, 3.0 Slot thick)
  • Clearances - Graphics Card 357mm x 79mm x 180mm (Expansion, 3.9 Slot thick)
  • Clearances - Graphics Card (Maximum space including GPU power connector)
  • Cable Routing - Behind MB Tray 11mm
  • Dust Filters Side panels
  • Power Supply Support SFX
  • Warranty 2 years (Case), 2 years (Thermal Solution), 10 years (Power Delivery)
  • Size Mini ITX
