MWE Gold V4 image number 0
MWE Gold V4 image number 1
MWE Gold V4 image number 2
MWE Gold V4 image number 3
MWE Gold V4 image number 4
MWE Gold V4 image number 5
MWE Gold V4
MWE Gold V4
MWE Gold V4
MWE Gold V4
MWE Gold V4
MWE Gold V4
The Intelligent Guardian
MWE Gold V4
GPU Shield™ Intelligent Current Management (Patent Applied For) ​
80 Plus Gold efficiency​​
Digital Control PSU ​​
Wave-type heatsink design​​
ATX 3.1 & PCIe 5.1 Standards Support ​
Low-noise Design
Conformal Coating
10-year warranty
Automatically detects abnormal current, adjusts output in real time, and alerts users through LED indicators for safer, more stable power delivery.
Digital Control IC
Engineered with digital control IC to achieve precise digital tuning of PFC and LLC, improving the overall efficiency 3% higher than previous series.
Digital Control IC
Digital Control IC
750W / 850W
Includes the same optimized cable configuration, designed for reliable performance and clean system builds.
750W / 850W
750W / 850W
1000W
Features an enhanced cable configuration to support higher power demands and advanced high-performance setups.
1000W
1000W
Equipped with the latest standard and 12V-2x6 output connector, ready for next-gen flagship graphics cards.
Low-noise Design
Engineered to achieve a lab-level noise control to deliver quiet power operation.
Conformal Coating
Protective coating that improves durability and safeguards components in harsh environments.
10-year warranty
This unit comes with a standard limited manufacturing warranty of 10 years from the date of purchase.
  • Model 750: MPX-7503-AFAG-2***
  • Input Current 10-5A
  • Fan Bearing HDB
  • Fan Speed 2500 RPM
  • 80 PLUS Rating 80 PLUS Gold
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 6
  • PCI-e 6+2 Pin Connectors 4
  • 12V-2x6 Connectors 1
  • Series MWE Gold Series
  • Category Above 750W
  • 80 Plus Efficiency Gold
  • Watts 750W
