null image number 0
null image number 1
null image number 2
null image number 3
null image number 4
null image number 5
null image number 6
null image number 7
null image number 8
null image number 9
null image number 10
null image number 11
null
null
null
null
null
null
null
null
null
null
null
null
Full Modular 80 Plus Gold PSU
MWE Gold 1050 - V2 Full Modular
80 PLUS Gold Efficiency
RTX Ready
140mm Silent Fan
High Temperature Resilience
Full Modular Cabling
10 Year Warranty
Model
Buy Now
Quiet Cooling
Silence Fan with Smart Temp. Controlling Feature
MWE Gold 1050 & 1250 are equipped with a 140mm silence fan with smart temperature controlling feature. The fan supports 0 RPM to achieve 0 noise based on the scenario.
RTX Ready
80 PLUS Gold Certified
  • Model MPE-A501-AFCAG
  • ATX Version ATX 12V V2.52
  • Input Current 13-6A
  • Input Frequency 47-63Hz
  • Fan Size 140mm
  • Fan Bearing FDB
  • Fan Speed 2200 RPM
  • Noise Level @ 20% 0 dBA
  • Noise Level @ 50% 14.9 dBA
  • Noise Level @ 100% 27.3 dBA
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time >20ms at 100% Load
  • Regulatory TUV, cTUVus, CE, BSMI, FCC, CCC, EAC, RCM, KCC, CB, UKCA
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 12
  • PCI-e 6+2 Pin Connectors 6
  • Warranty 10 Years
  • Series MWE Gold Series
  • Category Above 750W
  • 80 Plus Efficiency Gold
  • Watts 1050W
