MWE Bronze 650 V3 image number 0
MWE Bronze 650 V3 image number 1
MWE Bronze 650 V3 image number 2
MWE Bronze 650 V3 image number 3
MWE Bronze 650 V3 image number 4
MWE Bronze 650 V3 image number 5
MWE Bronze 650 V3 image number 6
MWE Bronze 650 V3 image number 7
MWE Bronze 650 V3
MWE Bronze 650 V3
MWE Bronze 650 V3
MWE Bronze 650 V3
MWE Bronze 650 V3
MWE Bronze 650 V3
MWE Bronze 650 V3
MWE Bronze 650 V3
Power Evolved
MWE Bronze 650 V3
ATX 3.1 support
High temperature resilience
Quiet HDB fan
80 Plus Bronze certified efficiency
Embossed cable
5-year warranty
ATX 3.1 Support
Compliant with ATX 3.1 to fully support a peak power 1.5 times higher than the rated maximum wattage, this unit is ideal for use with the 40 series GPUs.
Embossed Cable
Quiet HDB Fan
Certified Efficiency
The MWE Bronze V3 is certified to achieve more than 85% efficiency at typical loads.​​
High Temperature Resilience
  • Model MPE-6501-ACAAW-3B
  • Input Current 10-5A
  • Fan Bearing HDB
  • Efficiency >85% @ Typical Load
  • Hold Up Time >16ms
  • SATA Connectors 6
  • PCI-e 6+2 Pin Connectors 4
  • Warranty 5 Years
  • Series MWE Bronze Series
  • Category 500 to 750W
  • Modular Non Modular
  • 80 Plus Efficiency Bronze
  • Watts 650W
