MWE Bronze 450 image number 0
MWE Bronze 450 image number 1
MWE Bronze 450 image number 2
MWE Bronze 450 image number 3
MWE Bronze 450 image number 4
MWE Bronze 450 image number 5
MWE Bronze 450 image number 6
MWE Bronze 450 image number 7
MWE Bronze 450 image number 8
MWE Bronze 450 image number 9
MWE Bronze 450 image number 10
MWE Bronze 450
MWE Bronze 450
MWE Bronze 450
MWE Bronze 450
MWE Bronze 450
MWE Bronze 450
MWE Bronze 450
MWE Bronze 450
MWE Bronze 450
MWE Bronze 450
MWE Bronze 450
80 PLUS Bronze Certified Power Supply
MWE Bronze 450
80 PLUS Bronze
DC-DC circuit design
Quality Capacitors
Durable LDB Bearing
Low Standby Power Consumption
Sleeved Cables
  • Operation Voltage 100-240Vac
  • ErP 2013 Lot 6 Yes
  • MB 20+4 Pin Connectors 1
  • Fan Bearing LDB
  • Category Under 500W
  • Modular Non Modular
  • ATX Version ATX 12V V2.31
  • 80 Plus Efficiency Bronze
  • Efficiency 85% Typically
  • Input Voltage 100-240Vac
  • PCI-e 6+2 Pin Connectors 2
  • Protections OVP
  • Series MWE Bronze Series
  • Protections OPP
  • SATA Connectors 4
  • Protections SCP
  • Protections OTP
  • Protections OCP
  • Input Current 8-4A
  • Model MPX-4501-ACAAB
  • Regulatory CCC
  • Regulatory CE
  • Product Name MWE Bronze 450
  • Regulatory TUV-RH
  • Regulatory RCM
  • Regulatory EAC
  • Regulatory cTUVus
  • Regulatory FCC
  • Regulatory BSMI
  • Regulatory KC
