MWE 650 Bronze - V2 image number 0
MWE 650 Bronze - V2 image number 1
MWE 650 Bronze - V2 image number 2
MWE 650 Bronze - V2 image number 3
MWE 650 Bronze - V2 image number 4
MWE 650 Bronze - V2 image number 5
MWE 650 Bronze - V2 image number 6
MWE 650 Bronze - V2 image number 7
MWE 650 Bronze - V2 image number 8
MWE 650 Bronze - V2
MWE 650 Bronze - V2
MWE 650 Bronze - V2
MWE 650 Bronze - V2
MWE 650 Bronze - V2
MWE 650 Bronze - V2
MWE 650 Bronze - V2
MWE 650 Bronze - V2
MWE 650 Bronze - V2
80 PLUS Bronze Certified Power Supply
MWE 650 Bronze - V2
DC-to-DC Technology
120mm HDB Fan
80 PLUS Bronze Efficiency
Flat, Black Cables
5 Year Warranty
DC-to-DC Circuit Design
The efficiency of your power supply unit is important because it directly affects you system’s performance and your power bill. The efficiency rating does not reflect the quality or reliability of a PSU. It only reflects the unit’s ability to move power from the wall to your components. The higher a PSU’s efficiency is, the lower the total amount of power it needs to power your system. The MWE Bronze series has an 80 PLUS Bronze efficiency rating, meaning it has a guaranteed typical efficiency of 85%.
Active Power Factor Correction
The many processes required by a power supply unit in order to take power directly from the wall or other fixed power source, convert it to the correct output required by the connected components, and then distribute that power to said components safely can be full of risks. This is why it’s important for a PSU to have the right protections and regulations to ensure this process runs correctly.
The MWE Bronze’s Active Power Factor Correction uses a specialized circuit to correct power factor, leading to reduced total harmonics, corrected AC input voltage, and increased overall efficiency output.
120mm HDB Fan
  • Model MPE-6501-ACAAB
  • ATX Version ATX 12V V2.52
  • Input Current 10-5A
  • Fan Bearing HDB
  • Fan Speed 2400 RPM
  • Noise Level @ 20% 11.06 dBA
  • Noise Level @ 50% 22.3 dBA
  • Noise Level @ 100% 41.3 dBA
  • Efficiency 85% Typically
  • Operating Temperature 40°C
  • Hold Up Time >18ms at 100% Full Load@230Vac
  • Regulatory CCC, CE, TUV-RH, RCM, EAC, cTUVus, FCC, BSMI, KC, CB
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 8
  • PCI-e 6+2 Pin Connectors 4
  • Series MWE Bronze Series
  • Category 500 to 750W
  • Modular Non Modular
  • 80 Plus Efficiency Bronze
  • Watts 650W
