MWE 550 White - V2 image number 0
MWE 550 White - V2 image number 1
MWE 550 White - V2 image number 2
MWE 550 White - V2 image number 3
MWE 550 White - V2 image number 4
MWE 550 White - V2 image number 5
MWE 550 White - V2 image number 6
MWE 550 White - V2 image number 7
MWE 550 White - V2 image number 8
MWE 550 White - V2
MWE 550 White - V2
MWE 550 White - V2
MWE 550 White - V2
MWE 550 White - V2
MWE 550 White - V2
MWE 550 White - V2
MWE 550 White - V2
MWE 550 White - V2
80 Plus Standard Certified Power Supply with DC-to-DC + LLC
MWE 550 White - V2
80 PLUS Standard Certified
120 mm HDB Fan
DC-to-DC + LLC Circuit Design
Single +12V Rail
Flat Black Cables
  • Efficiency 80% Typically Load
  • Category 500 to 750W
  • Modular Non Modular
  • Fan Bearing HDB
  • 80 PLUS Rating 80 PLUS Standard
  • Noise Level @ 20% 10.43 dBA
  • 80 Plus Efficiency White
  • PCI-e 6+2 Pin Connectors 2
  • SATA Connectors 6
  • Fan Speed 1500 RPM
  • Operating Temperature 40°C
  • ATX Version ATX 12V V2.52
  • Protections OVP
  • Protections OPP
  • Series MWE White Series
  • Noise Level @ 50% 16.8 dBA
  • Hold Up Time >14ms at 100% Full Load@230Vac
  • Protections SCP
  • Protections UVP
  • Protections OTP
  • Input Current 8-4A
  • Noise Level @ 100% 31.5 dBA
  • Regulatory CCC
  • Regulatory CE
  • Regulatory RCM
  • Regulatory EAC
  • Regulatory cTUVus
  • Regulatory FCC
  • Regulatory BSMI
  • Regulatory KC
  • Regulatory CB
  • Regulatory TUV
  • Model MPE-5501-ACAAW
