MWE 450 Bronze - V2 image number 0
MWE 450 Bronze - V2 image number 1
MWE 450 Bronze - V2 image number 2
MWE 450 Bronze - V2 image number 3
MWE 450 Bronze - V2 image number 4
MWE 450 Bronze - V2 image number 5
MWE 450 Bronze - V2 image number 6
MWE 450 Bronze - V2 image number 7
MWE 450 Bronze - V2 image number 8
MWE 450 Bronze - V2
MWE 450 Bronze - V2
MWE 450 Bronze - V2
MWE 450 Bronze - V2
MWE 450 Bronze - V2
MWE 450 Bronze - V2
MWE 450 Bronze - V2
MWE 450 Bronze - V2
MWE 450 Bronze - V2
80 PLUS Bronze Certified Power Supply
MWE 450 Bronze - V2
DC-to-DC Technology
120mm HDB Fan
80 PLUS Bronze Efficiency
Flat, Black Cables
5 Year Warranty
80 PLUS BRONZE EFFICIENCY
DC-TO-DC CIRCUIT DESIGN
120MM HDB FAN
ACTIVE POWER FACTOR CORRECTION
TECH SPECS
CABLE LENGTH & OUTPUT RATING
FLAT, BLACK CABLES
  • EPS 4+4 Pin Connectors 1
  • Noise Level @ 20% 10.1 dBA
  • Category Under 500W
  • Modular Non Modular
  • Fan Bearing HDB
  • Efficiency 85% Typically
  • 80 Plus Efficiency Bronze
  • PCI-e 6+2 Pin Connectors 2
  • SATA Connectors 6
  • Fan Speed 1500 RPM
  • Operating Temperature 40°C
  • Series MWE Bronze Series
  • Noise Level @ 100% 28.2 dBA
  • ATX Version ATX 12V V2.52
  • Protections OVP
  • Protections OPP
  • Noise Level @ 50% 15.8 dBA
  • Protections SCP
  • Protections UVP
  • Protections OTP
  • Input Current 8-4A
  • Regulatory CCC
  • Regulatory CE
  • Regulatory TUV-RH
  • Hold Up Time >18ms at 100% Full Load@230Vac
  • Regulatory RCM
  • Regulatory EAC
  • Regulatory cTUVus
  • Regulatory FCC
  • Regulatory BSMI
  • Regulatory KC
  • Regulatory CB
  • Model MPE-4501-ACAAB
