MWE 400 White 230V - V2 image number 0
MWE 400 White 230V - V2 image number 1
MWE 400 White 230V - V2 image number 2
MWE 400 White 230V - V2 image number 3
MWE 400 White 230V - V2 image number 4
MWE 400 White 230V - V2 image number 5
MWE 400 White 230V - V2 image number 6
MWE 400 White 230V - V2 image number 7
MWE 400 White 230V - V2 image number 8
80 PLUS Standard 230V EU Certified Power Supply
120mm HDB Fan
DC-to-DC Technology
Single +12V Rail
Flat Black Cables
  • Category Under 500W
  • Fan Bearing HDB
  • Modular Non Modular
  • Input Current 4A
  • Efficiency 85% Typically
  • 80 Plus Efficiency White
  • 80 PLUS Rating 80 PLUS Standard 230V EU
  • Fan Speed 1500 RPM
  • Operating Temperature 40°C
  • SATA Connectors 6
  • PCI-e 6+2 Pin Connectors 1
  • Protections OVP
  • ATX Version ATX 12V V2.52
  • Series MWE White Series
  • Protections OPP
  • Protections SCP
  • Hold Up Time >14ms at 100% Full Load@230Vac
  • Protections UVP
  • Protections OTP
  • Noise Level @ 50% 17.7 dBA
  • Noise Level @ 100% 30.4 dBA
  • Regulatory CCC
  • Input Voltage 200-240Vac
  • Regulatory CE
  • Noise Level @ 20% 13.4 dBA
  • Regulatory TUV-RH
  • Regulatory RCM
  • Regulatory EAC
  • Regulatory cTUVus
  • Regulatory FCC
  • Regulatory BSMI
  • Regulatory KC
  • Regulatory CB
  • Model MPE-4001-ACABW
