Mobius 140P ARGB image number 0
Mobius 140P ARGB image number 1
Mobius 140P ARGB image number 2
Mobius 140P ARGB
Mobius 140P ARGB
Mobius 140P ARGB
More Balance, More Burst
Mobius 140P ARGB
Ring Blade Design (RBD)
Pressure Air Acceleration
Absolute Acoustics
Luminescent Light Effects
Addressable Gen 2 RGB
Anti-vibration Damper
Absolute Acoustics
Sound output fine tuned to the optimal prominence ratio
to achieve sub 6dB noise levels without performance sacrifice.
Acoustic Testing
Anechoic Chamber for ISO 3745
• Sound Pressure: IS0-7779
• Sound Power: ISO-7779
Oil Reflow
Dust Proofing
Anti-sway System
  • Product Number MFZ-M4DN-19NP2-R1
  • Exterior Color Black
  • Fan Dimensions (L x W x H) 140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
  • Fan Speed 0-1900 RPM ± 10%
  • Fan Airflow 76.5 CFM
  • Fan Noise Level 30 dBA
  • Fan Air Pressure 2.3 mmH₂O
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.35A
  • Fan Safety Current 0.4A
  • Fan Power Consumption 4.2W
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.48A
  • Fan Weight 222 g / 0.49 lbs
  • Warranty 5 years
  • Cooler Type Case Fan
  • Series Mobius Series
  • Fan Size 140
  • Number of LEDs 8pcs
  • LED Lighting ARGB
