Mobius 120P ARGB White Edition 3-pack Fan Kit image number 0
Mobius 120P ARGB White Edition 3-pack Fan Kit image number 1
Mobius 120P ARGB White Edition 3-pack Fan Kit image number 2
Mobius 120P ARGB White Edition 3-pack Fan Kit image number 3
Mobius 120P ARGB White Edition 3-pack Fan Kit image number 4
More Balance, More Burst
  • Ring Blade Design (RBD)
  • Pressure Air Acceleration
  • Absolute Acoustics
  • Luminescent Light Effects
  • Addressable Gen 2 RGB
  • New Mini A1 controller
PERFECTING ENGINEERING
Cooler Master’s Mobius120P ARGB White Edition is a part of our highest performing series of fans. With an innovative ring blade design, the Mobius series optimizes for both performance and acoustics. Catering to a wide range of applications, cases, and cooling set ups, the Mobius 120P can suit the needs of any build.
RING BLADE DESIGN (RBD)
LOOP DYNAMIC BEARING
OIL REFLOW
ANTI-SWAY SYSTEM
DUST PROOFING
PRESSURE AIR ACCELERATION
An angled inner frame rim with chamfered side vents boosts air intake, maximizes air flow, and eliminates dead spots.
ABSOLUTE ACOUSTICS
Sound output fine tuned to the optimal prominence ratio to achieve sub 6dB noise levels without performance sacrifice.
Acoustic Testing
Anechoic Chamber for ISO 3745
• Sound Pressure: IS0-7779
• Sound Power: ISO-7779
ANTI-VIBRATION DAMPER
Our Achievements
10
AWARDS
  • Product Number MFZ-M2DW-243P2-R1
  • Exterior Color White
  • Fan Speed 0-2400 RPM ± 10%
  • Fan Airflow 75.2 CFM
  • Fan Noise Level 30 dBA
  • Fan Air Pressure 3.63 mmH2O
  • Fan MTTF >200,000 Hours
  • Fan Connector 4-Pin PWM
  • Fan Rated Current 0.18A
  • Fan Rated Current 0.35A
  • Fan Power Consumption 2.16W
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.48A
  • Fan Weight 179g / 0.38 lbs
  • Warranty 5 years
  • Cooler Type Case Fan
  • Series Mobius Series
  • LED Lighting ARGB
  • Fan Size 120
