Mobius 120 Slim image number 0
Mobius 120 Slim image number 1
Mobius 120 Slim image number 2
Mobius 120 Slim image number 3
Mobius 120 Slim image number 4
Mobius 120 Slim
Mobius 120 Slim
Mobius 120 Slim
Mobius 120 Slim
Mobius 120 Slim
More Balance, More Burst
Mobius 120 Slim
Ring Blade Design (RBD)
Pressure Acceleration Air Vents
Thin frame design
Upgraded three-phase motor
PERFECTING THE ENGINEERING
Cooler Master’s is Introducing the latest innovation in Cooler Master’s critically-acclaimed Mobius case fan series: the Mobius 120 Slim. This updated model has been redesigned with a thinner frame, perfect for small form factor builds that have limited space but need more airflow. Features such as an interconnecting ring blade design accelerated pressure air vents, and an upgraded three-phase motor ensure exceptional stability and silent performance. Want to really stack your build with multiple GPUs, or maybe customize your case with figures? Then you’ll need to free up space while still keeping things cool. Trim down your build with the Mobius 120 Slim.
OIL REFLOW
DUST PROOFING
ANTI-SWAY SYSTEM
The angled inner frame rim with chamfered side vents boosts airflow draw. The structural ring blade eliminates fan deformation, keeping the fan's build rigid.
  • Product Number MFZ-S2NN-25NPK-R1
  • Exterior Color Black
  • Fan Dimensions (L x W x H) 120 x 120 x 15 mm / 4.7 x 4.7 x 0.6 inch
  • Fan Profiles Non-LED
  • Fan Speed 2500 RPM ± 10%
  • Fan Airflow 53.7 CFM
  • Fan Noise Level 31.4 dBA
  • Fan Pressure 2.53 mmH₂O
  • Fan MTTF >200,000 Hours
  • Fan Rated Current 0.2A
  • Fan Safety Current 0.3A
  • Fan Power Consumption 2.4W
  • Fan Weight 105g / 0.23 lbs
  • Warranty 5 years
  • Cooler Type Case Fan
  • Series Mobius Series
  • LED Lighting Non-LED
  • Fan Size 120
