MM712 Wired Gaming Mouse image number 0
MM712 Wired Gaming Mouse image number 1
MM712 Wired Gaming Mouse image number 2
MM712 Wired Gaming Mouse image number 3
MM712 Wired Gaming Mouse image number 4
MM712 Wired Gaming Mouse image number 5
MASTERY REBORN
Our legendary Pro-level Gaming Mouse, fast, precise, and superlight.
Step into the realm of legends with the Cooler Master MM712-Wired. Dominate the game, seize victory, and leave your mark as an unstoppable force in the gaming universe. Elevate your gameplay, elevate your mastery.
The 49 Gram Legacy – Our Lightest Mouse Yet
What truly sets the MM712 apart is its class-leading weight. Engineered with a cleverly structured chassis and a superlight frame weighing just 49 grams, this mouse feels like an extension of your hand, effortlessly gliding across your gaming surface. Say goodbye to fatigue during intense gaming marathons—the MM712’s ergonomic design ensures comfort and control through every high-stakes battle and extensive work session.
Center Stage
Center Stage
With feedback from our community of gamers, the MM712 now positions the sensor dead center of its mass, ensuring perfectly balanced weight distribution and a consistent feel during lifts and swipes.
Zero Pull, Frictionless Glide from Superior PTFE Feet
Redesigned curved-edge PTFE feet make the MM712 glide effortlessly across any surface with zero cable pull.
Cooler Master Exclusive Ultraweave Cable
Exceptionally lightweight and designed for tighter control, Ultraweave eliminates cable snag and reduces drag for quicker and smoother swipes in the heat of the battle.
The Masterkey with On-Board Safe-Keeping
The new MasterPlus+ software from Cooler Master unlocks the MM712’s full potential. Adjust your settings, remap buttons, set up macros and profiles, and more. Once configured, all your settings are stored directly on the device, providing a true plug-and-play experience with a set-it-and-forget-it convenience.
* The software only supports Windows 7 and above.
Learn More
Set Your Style, Your Team Colors, Your Mood
Personalize your mouse in style with 16.7M customizable illuminating RGB colors. Sync colors across all your Cooler Master devices or adjust RGB effects in real time via key combos or MasterPlus+ Software.
Wheel + Forward = Change LED color
Wheel + Backward = Cycle LED modes
  • Product Number MM-712-KKOL1
  • Mouse Grip Type Claw, Palm, Fingertip
  • Mouse Material ABS Plastic
  • Mouse Feet PTFE
  • Mouse Color Black
  • Mouse LEDs Yes, RGB on logo
  • Mouse Sensor PixArt PWM3395
  • CPI / DPI 400-800-1200(Default)-1600-3200-8000-26000
  • Mouse Tracking Speed 650 ips
  • Mouse Lift Off Distance < ~2mm
  • Mouse Polling Rate 1000Hz
  • Angle Snapping Yes
  • Mouse acceleration 50g
  • On-board Memory 512KB
  • Mouse Lifespan (L/R switches) Optical Switches, 70 Million
  • Mouse Buttons 6
  • Software Yes, Cooler Master MasterPlus+ Support
  • Mouse Cable Length Fixed Ultraweave cable, 1.8m
  • Mouse Dimensions 116.5 x 62.4 x 38.3 mm / 4.587 x 2.457 x 1.508 inches (L x W x H)
  • Mouse Weight < 50g
  • Product Mice
