MM711 LITE RGB Gaming Mouse image number 0
MM711 LITE RGB Gaming Mouse image number 1
MM711 LITE RGB Gaming Mouse image number 2
MM711 LITE RGB Gaming Mouse image number 3
MM711 LITE RGB Gaming Mouse image number 4
Less Pain, More Game
The MM711 LITE is the base version of our innovative mouse, giving you the same essential features for considerably less.
  • Mouse Grip Type Palm
  • Mouse Color Black
  • Mouse Feet PTFE
  • Mouse Buttons 6
  • Mouse Material ABS Plastic
  • Mouse Grip Type Claw
  • Product Mice
  • Mouse Polling Rate 1000Hz
  • Mouse Lifespan (L/R switches) Mechanical Micro Switch, 60M
  • Angle Snapping Yes
  • Software Support N/A
  • Surface Treatment Matte Finish
  • Mouse acceleration 20g
  • Mouse Grip Type Fingertip
  • Mouse LEDs Yes, RGB on wheel and logo
  • Mouse Cable Length Fixed Braided cable, 1.8m
  • Mouse Tracking Speed 100 ips
  • Mouse Lift Off Distance < ~2mm
  • CPI / DPI 7 Levels, 400(Yellow) - 800(Blue) - 1200(Purple/Default) - 1600(Green) - 3200(Cyan) - 6400(Orange) - 10000(Red)
  • Mouse Sensor PixArt Optical Sensor
  • Mouse Weight 59g / 0.13 lbs (without USB Cable)
  • Dimensions (L x W x H) 116.5 x 62.4 x 38.3 mm / 4.59 × 2.46 × 1.51 inch
  • Product Number MM-711-KKOL3
