MM310 SF6 Chun-Li Gaming Mouse image number 0
MM310 SF6 Chun-Li Gaming Mouse image number 1
MM310 SF6 Chun-Li Gaming Mouse image number 2
MM310 SF6 Chun-Li Gaming Mouse image number 3
MM310 SF6 Chun-Li Gaming Mouse image number 4
MM310 SF6 Chun-Li Gaming Mouse image number 5
The MM310 is a wired gaming mouse buffed with an innovative new feature set focused on performance. This includes pro-grade 12,000 DPI optical sensor, genuine PTFE feet for unrivaled glide, and new Ultraweave cable for snag-free, drag-free gaming. All housed in a revolutionary lightweight shell design that reduces the weight to a nimble 50g. Light on weight but heavy on performance, the MM310 truly floats above the rest.
©CAPCOM CO., LTD. ALL RIGHTS RESERVED.
Special Edition
Cooler Master
x Capcom Street Fighter 6
The MM310 wired gaming mouse, with its exclusive
color scheme and design, weaves together the aesthetics
of Street Fighter 6 and Cooler Master's gaming expertise,
embodying the spirit of Chun-Li.
Design
Lightweight Ambidextrous Design
Optimized for right-handers with two side buttons and weighs in at 50g without exterior holes that compromise on aesthetics.
 Customizable Features
MasterPlus+ Support
New, improved software allows you to remap controls, customize your RGBs, tune your macros, and more.
Cable
Ultraweave Cable
Super lightweight and engineered in-house to prevent cable snag when swiping.
Illumination
RGB Lighting
Give your victories some flashy good looks
with lighting on the logo and the scroll wheel.
Adjustability
Gaming Grade Sensor
Adapt to your game or playstyle with optical sensor
adjustable up to 12,000 DPI.
Performance
Upgraded Mouse Feet
New-and-improved feet made with PTFE material for low friction and high durability, which provides a smooth, fast glide with maximum responsiveness.
  • Product Number MM-310-WWOL2
  • Mouse Grip Type Palm / Claw
  • Mouse Material ABS Plastic / Rubber / PTFE
  • Mouse Color Special Design for SF6 Chun-Li
  • Mouse LED Color 16.7 Million RGB
  • Mouse Sensor PixArt Optical Sensor
  • CPI / DPI 400-800-1,200(Default)-1600-3200-6200-12000
  • Mouse Tracking Speed 220 ips
  • Mouse Lift Off Distance N/A
  • Mouse Polling Rate 125 / 250 / 500 / 1000 MHz (Switch via software)
  • Angle Snapping Yes
  • Mouse acceleration 30g
  • Mouse Lifespan (L/R switches) Mechanical Micro Switch, 60M
  • Mouse Buttons 6
  • Connectivity Wired
  • Compatible OS Windows8+ / macOS
  • Software Yes, Cooler Master MasterPlus+ Support
  • Mouse Cable Ultraweave Cable, 1.8 M (Type-C to Type-A) with Gold-plated
  • Mouse Dimensions 125.5 x 71.0 x 40.5 mm / 4.94 x 2.80 x 1.59 inches
  • Mouse Weight 50g / 0.11 lbs (w/o Cable)
  • Product Mice
