MK721 30th Anniversary Edition Gaming Keyboard image number 0
MK721 30th Anniversary Edition Gaming Keyboard image number 1
MK721 30th Anniversary Edition Gaming Keyboard image number 2
MK721 30th Anniversary Edition Gaming Keyboard image number 3
MK721 30th Anniversary Edition Gaming Keyboard image number 4
MK721 30th Anniversary Edition Gaming Keyboard image number 5
MK721 30th Anniversary Edition Gaming Keyboard image number 6
MK721 30th Anniversary Edition Gaming Keyboard image number 7
Your Everyday PC Carry
The MK721 wireless mechanical keyboard redefines the daily driver, striking the perfect balance between form and function for both work and play.
  • Keyboard Type Mechanical
  • Product Keyboard
  • Keyboard Material Plastic
  • Charging Support Wired charging
  • Keyboard Extra Keycap Set PBT Double Shot
  • Keyboard Extra Keycap Set OEM Profile
  • Keyboard Response Time 1ms (Wired/2.4GHz Mode)
  • Battery Life 73hrs (LED Off)
  • Keyboard Response Time 8ms (Bluetooth Mode)
  • Connectivity Wired
  • Connectivity 2.4 GHz
  • Keyboard Material Aluminum
  • Keyboard Polling Rate 125Hz (Bluetooth Mode)
  • Compatible OS Windows 8+
  • Battery 2000mAh
  • Compatible OS Mac OS X 10.10+
  • Connectivity Bluetooth 5.1
  • Keyboard Polling Rate 1000Hz (Wired/2.4GHz Mode)
  • Compatible OS Android
  • Software Support Cooler Master MasterPlus+
  • Wrist rest Cloth/SBR, 334 x 95 x 18 mm
  • Keyboard LED Color RGB, 16.7 million colors
  • Compatible OS iOS
  • Keyboard Cable USB Type C to Type A
  • Keyboard Cable 1.6m
  • Keyboard Keycaps OEM Profile
  • On-the-fly System Yes, via FN
  • Keyboard Cable Detachable & Coiled Braided
  • Keyboard Keycaps PBT Double-Shot
  • Keyboard Dimensions (L x W x H) Standard: 334 x 118 x 37 mm / 13.15 x 4.65 x 1.46 inches
  • Keyboard Dimensions (L x W x H) With 1st stage feet open: 334 x 118 x 43 mm / 13.15 x 4.65 x 1.69 inches
  • Keyboard Dimensions (L x W x H) With 2nd stage feet open: 334 x 118 x 46 mm / 13.15 x 4.65 x 1.81 inches
  • Keyboard Weight 764g / 1.68 lbs (without Cable & Dongle)
  • Keyboard Switch Type Kailh Box V2 Mechanical Switch (Red/White/Brown)
  • Product Number MK-721-CKTR1/L1/M1-US
