MasterCase MC500 High Storage Edition image number 0
MasterCase MC500 High Storage Edition image number 1
MasterCase MC500 High Storage Edition image number 2
MasterCase MC500 High Storage Edition image number 3
MasterCase MC500 High Storage Edition image number 4
Designed for Storage Focused Builds
MasterCase MC500 supports mammoth storage of up to ten HDDs and two SDDs, adjustable in position to allow for multiple system configurations...
  • Series MasterCase Series
  • Materials Steel
  • Dust Filters Top
  • Dust Filters Front
  • I/O Panel 2x USB 3.0
  • Radiator Support - Rear 140mm
  • Materials Plastic
  • Size Mid Tower
  • Pre-installed Fans - Front 2x 140mm, 1200RPM
  • Power Supply Support ATX
  • Dust Filters Bottom
  • Cable Routing 25-35mm
  • I/O Panel 2x USB 2.0
  • Motherboard Support ATX
  • Expansion Slots 7
  • Clearance - GFX 296mm (w/ 3.5" HDD cage)
  • Color(s) Dark metallic grey exterior with black interior
  • Fan Support - Top 2x 120mm
  • Clearance - CPU Cooler 190mm
  • Dimensions (L x W x H) 512 x 235 x 548 mm
  • 2.5" / 3.5" Drive Bays (Combo) 10
  • Clearance - GFX 412mm (w/o 3.5" HDD cage)
  • 2.5" Drive Bays 2 (Max. 4 SSD)
  • Model Number MCM-M500-KNNN-S00
