MasterWatt Lite 230V 500W image number 0
MasterWatt Lite 230V 500W image number 1
MasterWatt Lite 230V 500W image number 2
MasterWatt Lite 230V 500W image number 3
MasterWatt Lite 230V 500W image number 4
MasterWatt Lite 230V 500W image number 5
MasterWatt Lite 230V 500W image number 6
MasterWatt Lite 230V 500W image number 7
MasterWatt Lite 230V 500W image number 8
MasterWatt Lite 230V 500W image number 9
ERP2013 230V
• 80 Plus EU (230V) certified 85% efficiency
• APFC + PWM combined with dual forward topology to increase stability and performance
• Green power design to meet ErP 2013 Lot6 & new CE energy saving regulation
• Silent 120mm HDB fan with intelligent fan-speed control, to enhance longevity and help reduce noise in power unit.
• Fully protection (OCP/OVP/SCP/OPP) with build-in Over Temperature Protection (OTP)
  • MB 20+4 Pin Connectors 1
  • Category 500 to 750W
  • Input Frequency 47-63Hz
  • Fan Size Silent 120mm HDB Fan
  • Modular Non Modular
  • Input Current 3.5-5A
  • Hold Up Time >10ms at 100% Full Load@230Vac
  • ATX Version ATX 12V V2.31
  • Efficiency 85% Typically
  • Series MasterWatt Lite Series
  • PCI-e 6+2 Pin Connectors 2
  • SATA Connectors 6
  • Protections OVP
  • Protections OPP
  • Protections SCP
  • Protections UVP
  • Protections OTP
  • Dimensions (L x W x H) 150 x 140 x 86 mm
  • Protections OCP
  • Regulatory CCC
  • Input Voltage 200-240Vac
  • Regulatory CE
  • Regulatory RCM
  • Regulatory EAC
  • Regulatory FCC
  • Regulatory BSMI
  • Regulatory KC
  • Regulatory CB
  • Model MPX-5001-ACABW
  • Regulatory TUV
  • Series Standard
  • Product Name MasterWatt Lite 230V (ErP 2013) 500W - Green power supply with ErP 2013 certified
  • Regulatory cTUV-Rhus
