MasterNotepal Pro image number 0
MasterNotepal Pro image number 1
MasterNotepal Pro image number 2
MasterNotepal Pro image number 3
MasterNotepal Pro image number 4
MasterNotepal Pro image number 5
MasterNotepal Pro
MasterNotepal Pro
MasterNotepal Pro
MasterNotepal Pro
MasterNotepal Pro
MasterNotepal Pro
What's Your Angle?
MasterNotepal Pro
Each piece of the MasterNotepal Series is modular, allowing you to build a desktop fortress of USB devices, strip it down into a thin aluminum surface
  • Material Plastic
  • Color Silver
  • Fan Dimensions (L x W x H) 80 x 80 x 10 mm / 3.2 x 3.2 x 0.4 inch
  • Power USB 5V DC
  • Cable USB 3.0 TYPE A to USB 3.0 Micro b
  • USB HUB USB 3.0 x 1
  • Legacy Cooling
  • USB HUB USB 2.0 x 3
  • Accessory Rubber Strip
  • Color Black
  • Fan Quantity 2 PCS
  • Material Aluminum
  • Accessory Rubber Hub Sleeve
  • Fan Airflow 15.42 CFM ± 10%
  • USB HUB USB 2.0 x 1 (Output)
  • USB HUB USB 3.0 Micro b x 1 (power supply and data transmission)
  • USB HUB USB 2.0 Micro b x 1 (external power)
  • Material Metal Mesh
  • Compatibility Supports up to 17" laptops
  • Weight 1.27kg
  • Fan Speed 2000 RPM ± 15%
  • Dimensions (L x W x H) 384.6 x 270 x 59.6mm
  • Fan Air Pressure 0.85 mmH2O
  • Fan Noise Level 27.24 dBA
  • Product Number MNY-SMTS-20FY-R1
