MasterMouse S Gaming Mouse image number 0
MasterMouse S Gaming Mouse image number 1
A Grip That Won't Let You Go
"Get in touch" with MasterMouse S and discover a pleasurable and satisfying grip brought about by its special contoured design and advanced surface...
  • Mouse Cable Length 1.8m / 70.9 in
  • Mouse Warranty 2 years
  • Programmable Profiles 5
  • Mouse Switches OMRON
  • Mouse Lifespan 20 million
  • Body coating Matte UV Coating
  • Mouse Processor 32 bit ARM processor
  • Mouse Grip Type Claw
  • On-board Memory 512KB
  • Mouse Connector Nickel-plated
  • Angle Snapping Yes
  • Mouse Tracking Speed 150 ips / 30 g
  • Mouse Lift Off Distance < ~2mm / Adjustable
  • Color Gun Black
  • Mouse Cable Black PVC Cable
  • CPI / DPI 4 Levels (400~7,200 DPI)
  • Legacy Peripherals
  • Programmable buttons 5
  • Mouse acceleration No
  • Mouse Material Plastic
  • Mouse Material Rubber
  • LED Color RGB, 16.7 million colors
  • Mouse Dimensions 117 x 63.5 x 38 mm / 4.6 x 2.5 x 1.5 inches
  • Mouse Weight 121g / 0.267 lbs
  • Mouse Weight 89g / 0.196 lbs (without USB Cable)
  • Mouse Sensor PixArt PMW3330 Optical
  • EAN Code 4719512054406
  • UPC Code 884102030505
  • Product Name MasterMouse S
  • Product Number SGM-2006-KSOA1
