MasterMouse Pro L Gaming Mouse image number 0
MasterMouse Pro L Gaming Mouse image number 1
Tactical Power in the Palm of Your Hand
Arm yourself with the MasterMouse Pro L and match your grip preference with extra modular top covers and side grips.
  • Mouse Cable Length 1.8m / 70.9 in
  • Mouse Warranty 2 years
  • Mouse Grip Type Palm
  • Programmable Profiles 5
  • Mouse Switches OMRON
  • Mouse Lifespan 20 million
  • Body coating Matte UV Coating
  • Mouse Connector Gold-plated
  • Mouse Tracking Speed 250 ips / 50 g
  • Mouse Grip Type Claw
  • On-board Memory 512KB
  • Mouse Processor 32 bit ARM processor
  • Programmable buttons 8
  • Mouse Cable Braided Cable
  • CPI / DPI 4 Levels (100~12,000 DPI) - Default = 400/1200/4000/12000
  • Angle Snapping Yes
  • Mouse Lift Off Distance < ~2mm / Adjustable
  • Color Gun Black
  • Legacy Peripherals
  • Mouse acceleration No
  • Mouse Material Plastic
  • Mouse Material Rubber
  • LED Color RGB, 16.7 million colors
  • Mouse Dimensions 125 (130) x 67.8 x 38 mm / 4.92 (5.12) x 2.67 x 1.5 inches
  • Mouse Weight 127 / 128g, 0.28 / 0.283 lbs
  • Mouse Weight 98 / 99g, 0.216 / 0.218 lbs (without USB Cable)
  • Mouse Sensor Avago PMW3360 Optical
  • Product Name MasterMouse Pro L
  • Product Number SGM-4006-KFOA1
