MasterMouse MM520 Gaming Mouse image number 0
MasterMouse MM520 Gaming Mouse image number 1
Great for Performance, Perfect for Claw Grips
The MasterMouse MM520 is the successor to the Spawn gaming mouse, improved further for claw grip gamers.
  • Mouse Grip Type Palm
  • DPI 12000
  • Mouse Memory 512 KB
  • Mouse Cable Length 1.8m / 70.9 in
  • Programmable Profiles 5
  • Mouse Processor 32 bit ARM Cortex M0
  • Mouse Switches OMRON
  • Mouse Lifespan 20 million
  • Body coating Matte UV Coating
  • Mouse Connector Gold-plated
  • Mouse Tracking Speed 250 ips / 50 g
  • Angle Snapping On/Off
  • Mouse Cable Flexible Cable
  • Product Mice
  • Mouse Grip Type Claw
  • Mouse Lift Off Distance < ~2mm / Adjustable
  • CPI / DPI 4 Levels (100~12,000 DPI) - Default = 400/1200/4000/12000
  • Mouse Weight (Without USB Cable) 101 g / 0.23 lbs
  • Programmable buttons 6
  • Mouse acceleration No
  • Mouse Material Plastic
  • DPI 4000
  • Color M14 Black
  • Mouse Material Rubber
  • Mouse Dimensions 78.5 x 118 x 29.5 mm / 3.09 x 4.65 x 1.16 Inches (L x W x H)
  • Mouse Weight 135g / 0.3 lbs
  • LED Color RGB, 16.7 million colors
  • Serie MasterMouse
  • DPI 1200
  • DPI 400
  • Mouse Sensor PixArt PMW3360 Optical
  • Product Number SGM-2007-KLON1
