MasterMouse Lite S Gaming Mouse image number 0
MasterMouse Lite S Gaming Mouse image number 1
A Grip That Won't Let You Go
The MasterMouse Lite S delivers a satisfying grip that just won't quit. With its special contoured design and advanced surface finish, you can take...
  • Mouse Cable Length 1.8m / 70.9 in
  • Mouse Color Black
  • Mouse Switches OMRON
  • Body coating Matte UV Coating
  • Mouse Lift Off Distance < ~4mm
  • Mouse Grip Type Claw
  • Mouse Connector Nickel-plated
  • Mouse Lifespan 10 million
  • Mouse Processor Soc
  • Mouse Tracking Speed 37 ips / 15 g
  • Legacy Peripherals
  • Mouse Cable Black PVC Cable
  • Mouse Polling Rate 125Hz / 8ms
  • Mouse Material Plastic
  • Mouse LED Color White
  • Mouse Material Rubber
  • CPI / DPI 3 Levels (600 / 1,000 / 2,000 DPI)
  • Mouse Dimensions 117 x 63.5 x 38 mm / 4.6 x 2.5 x 1.5 inches
  • Mouse Weight 123g / 0.271 lbs
  • Mouse Weight 86g / 0.189 lbs (without USB Cable)
  • Mouse Sensor PixArt PAW3509 Optical
  • EAN Code 4719512054413
  • UPC Code 884102030512
  • Product Name MasterMouse Lite S
  • Product Number SGM-1006-KSOA1
