MasterLiquid Pro 280 RGB image number 0
MasterLiquid Pro 280 RGB image number 1
MasterLiquid Pro 280 RGB image number 2
MasterLiquid Pro 280 RGB image number 3
MasterLiquid Pro 280 RGB image number 4
Dual Chamber & RGB Lighting
The MasterLiquid Pro 280 RGB is a Cooler Master original design and enables a colorful entry into liquid cooling.
  • Pump Connector 4-Pin
  • Legacy Cooling
  • Fan Quantity 2 PCS
  • Radiator Size 280
  • Pump Noise Level < 12 dBA (Max)
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Pump MTTF 175,000 Hours
  • Fan MTTF 160,000 Hours
  • Material Aluminum
  • Pump Dimensions 94.8 x 68 x 58.9 mm / 3.73 x 2.68 x 2.32 inch
  • Warranty 5 years
  • CPU Socket LGA1366
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • Fan Dimensions (L x W x H) 140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
  • Fan Air Pressure 1.3 mmH2O ± 10%
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • Fan Speed 650-1300 RPM ± 10%
  • CPU Socket FM2
  • CPU Socket FM1
  • Dimensions (L x W x H) 318 x 137 x 27.2 mm / 12.52 x 5.39 x 1.07 inch
  • Fan Airflow 79.6 CFM (Max)
  • Product Number MLY-D28M-A22PC-R1
