Global Headquarters
Optimized for AMD Threadrippers
Large, full-coverage copper base
Mobius 120 fans
All-in-one thermal solution
This edition of the MasterLiquid series has been specially designed for AMD TR5-SP6 CPUs only
The extensive copper base spreads heat more evenly across the cooling surface, allowing for quicker dissipation and maintaining lower CPU temperatures even under heavy loads.
Our critically acclaimed Mobius 120 fans provide both high-end thermal performance and unparalleled noise control
Pre-applied thermal paste and easy snap-on brackets make installation and set-up a breeze
