MasterLiquid PL360 Flux 30th Anniversary Edition image number 0
MasterLiquid PL360 Flux 30th Anniversary Edition image number 1
MasterLiquid PL360 Flux 30th Anniversary Edition image number 2
MasterLiquid PL360 Flux 30th Anniversary Edition image number 3
MasterLiquid PL360 Flux 30th Anniversary Edition image number 4
Premium Dual Chamber Pump
Fine Tuned Performance Ratio
Superior Heat Exchange
Low Profile Radiator
Redesigned Flux Series Fan
Dual Loop ARGB Pump
Cooler Master is releasing a limited version of the MasterLiquid Flux Series flagship liquid cooler to represent 30 years of success. The performance liquid cooler features the new Mobius Series 30th Anniversary Edition fans, exclusive pump cover with the 30th Anniversary logo, as well as unique limited edition print on the radiator. The PL360 Flux 30TH Anniversary Edition has refined performance from fans to the copper base, as well as unique aesthetic design to represent our decades worth of innovation.
Slim & Sleek Radiator
Low profile radiator with superior fin density coupled with performance fans dissipates heat rapidly.
Superior Performance Ratio
Precision engineered ultra-thin spaded fins maximize microchannels accurately to target heat spots. The enlarged copper base surface optimized with ideal base thickness accelerates heat transfer.
Dual Chamber Pump
Dual Chamber Pump
The compact Dual Chamber pump delivers the perfect balance of waterflow and pressure, decorated with the 30th Anniversary logo.
Ultimate Heat Exchange
A high speed motor utilizing a ceramic bearing impeller, which forces balanced waterflow to and from the radiator for ultimate efficiency of heat exchange.
  • Product Number MLY-D36M-A23PZ-30​
  • Exterior Color Black
  • CPU Socket Intel® LGA 1700 / 1200 / 2066 / 2011-v3 / 2011 / 1151 / 1150 / 1155 / 1156 socket
  • CPU Socket AMD® AM5 / AM4 / AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 / TR4 socket
  • Radiator Material Aluminum
  • Radiator Dimensions 394 x 119.6 x 27.2 mm / 15.5 x 4.7 x 1.07 inch
  • Pump Dimensions 89 x 75 x 40 mm / 3.5 x 2.95 x 1.57 inch
  • Pump MTTF >210,000 Hours
  • Pump Noise Level 15 dBA (Max)
  • Pump Connector 4-Pin
  • Pump Rated Voltage 12 VDC
  • Pump Power Consumption 6W
  • Fan Quantity 3 PCS
  • Fan LED Type Addressable Gen 2 RGB
  • Fan Speed 0-2400 RPM ± 10%
  • Fan Airflow 75.2 CFM (Max)
  • Fan MTTF >200,000 Hours
  • Fan Rated Current 0.18A
  • Fan Safety Current 0.35A
  • Patent Number US10739084B2, US11061450B2, US10409341B2, US11320874B2, US11474574B2
  • Warranty 5 years
  • Cooler Type Liquid Cooler
  • Series MasterLiquid Pro
  • Radiator Size 360
