MasterLiquid ML360P Silver Edition image number 0
MasterLiquid ML360P Silver Edition image number 1
MasterLiquid ML360P Silver Edition image number 2
MasterLiquid ML360P Silver Edition image number 3
MasterLiquid ML360P Silver Edition image number 4
MasterLiquid ML360P Silver Edition image number 5
MasterLiquid ML360P Silver Edition image number 6
MasterLiquid ML360P Silver Edition image number 7
MasterLiquid ML360P Silver Edition image number 8
MasterLiquid ML360P Silver Edition image number 9
MasterLiquid ML360P Silver Edition image number 10
MasterLiquid ML360P Silver Edition image number 11
The MasterLiquid ML360P Silver Edition is Cooler Master’s newly optimized liquid cooler to ensure maximum performance and elegant aesthetics...
  • Radiator Material Aluminum
  • Pump Rated Voltage 12 VDC
  • Pump MTTF 70,000 Hours
  • Radiator Size 360
  • Fan LED Color ARGB
  • Pump Power Connector 3-Pin
  • Cooler Type Liquid Cooler
  • CPU Socket LGA2066
  • Pump Power Consumption 1.3W (LED: 2.0W)
  • CPU Socket LGA2011-v3
  • Fan MTTF 160,000 Hours
  • Fan Power Connector 3-Pin ARGB
  • Pump Noise Level < 15 dBA (1m)
  • Waterblock Dimensions 82.9 × 72 × 52.9 mm / 3.3 × 2.8 × 2.1 inch
  • Radiator Dimensions 394 × 119 × 27.2 mm / 15.5 × 4.7 × 1.1 inch
  • CPU Socket LGA1700
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • Fan Noise Level 8 - 30 dBA
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Series MasterLiquid
  • CPU Socket TR4
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • Note *Accessory Pack Required, Please Refer to Landing Page or Technical Support
  • CPU Socket FM1
  • Fan Power Consumption 3.84W (LED: 7.2W)
  • Fan Air Pressure 1.58 mmH2O ± 10%
  • Fan Rated Current 0.32A (LED: 1.2A)
  • Fan Speed 650-1800 RPM
  • Fan Airflow 45 CFM ± 10%
  • Product Number MLY-D36M-A18PA-R1
