MasterLiquid ML360 Mirror image number 0
MasterLiquid ML360 Mirror image number 1
MasterLiquid ML360 Mirror image number 2
MasterLiquid ML360 Mirror image number 3
MasterLiquid ML360 Mirror image number 4
MasterLiquid ML360 Mirror image number 5
MasterLiquid ML360 Mirror image number 6
MasterLiquid ML360 Mirror image number 7
MasterLiquid ML360 Mirror image number 8
MasterLiquid ML360 Mirror image number 9
Cooler Master MasterLiquid ML360 Mirror comes with new lighting display effect using Infinity mirror to showcase an array of color.
  • Radiator Size 360
  • Radiator Material Aluminum
  • Pump Rated Voltage 12 VDC
  • Pump MTTF 70,000 Hours
  • Exterior Color Black
  • RAM Clearance N/A
  • Fan LED Type Non-LED
  • Cooler Type Liquid Cooler
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Power Connector 3-Pin
  • Fan Quantity 3 PCS
  • Fan Pressure 2.5 mmH₂O (Max)
  • Pump Power Consumption 2.36 W
  • CPU Socket LGA1700
  • Fan Life Expectancy 160,000 Hours
  • Pump Dimensions 81.2 x 76 x 57.8 mm / 3.19 x 3 x 2.3 inch
  • Pump Noise Level < 10 dBA
  • CPU Socket LGA1200
  • Radiator Dimensions 394 x 119.6 x 27.2 mm / 15.5 x 4.7 x 1.1 inch
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Series MasterLiquid
  • Fan Rated Current 0.15A
  • CPU Socket AM5
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Note For LGA 1700 mounting kits, You may obtain through the CM store, regional resellers and distributors. It's compatible with AMD AM5 although the package may not stress it.
  • Fan Noise Level 8 - 27 dBA
  • Fan Speed 650-1800 RPM ± 5%
  • Fan Airflow 62 CFM (Max)
  • Product Number MLX-D36M-A18PK-R1
