MasterLiquid ML280 RGB TR4 Edition image number 0
MasterLiquid ML280 RGB TR4 Edition image number 1
MasterLiquid ML280 RGB TR4 Edition image number 2
MasterLiquid ML280 RGB TR4 Edition image number 3
MasterLiquid ML280 RGB TR4 Edition image number 4
MasterLiquid ML280 RGB TR4 Edition image number 5
MasterLiquid ML280 RGB TR4 Edition image number 6
MasterLiquid ML280 RGB TR4 Edition image number 7
MasterLiquid ML280 RGB TR4 Edition image number 8
MasterLiquid ML280 RGB TR4 Edition image number 9
MasterLiquid ML280 RGB TR4 Edition image number 10
MasterLiquid ML280 RGB TR4 Edition image number 11
MasterLiquid ML280 RGB TR4 Edition image number 12
A New Way To Flow
  • Connector 3-Pin
  • Radiator Material Aluminum
  • Pump Rated Voltage 12 VDC
  • Pump MTTF 70,000 Hours
  • Fan Quantity 2 PCS
  • Radiator Size 280
  • Cooler Type Liquid Cooler
  • Fan MTTF 160,000 Hours
  • Pump Noise Level < 15 dBA
  • Pump Dimensions 86 x 70 x 49 mm / 3.4 x 2.8 x 1.9 inch
  • Series MasterLiquid
  • CPU Socket TR4
  • Fan Dimensions (L x W x H) 140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
  • Fan Air Pressure 1.3 mmH2O ± 10%
  • Dimensions (L x W x H) 318 x 137 x 27.2 mm / 12.52 x 5.39 x 1.07 inch
  • Fan Airflow 79.6 CFM (Max)
  • Fan Speed 600-1300 RPM (PWM) ± 10%
  • EAN code 4719512072288
  • UPC code 884102037535
  • Product Number MLX-D28M-A13PC-T1
