MasterLiquid ML240L V2 RGB image number 0
MasterLiquid ML240L V2 RGB image number 1
MasterLiquid ML240L V2 RGB image number 2
MasterLiquid ML240L V2 RGB image number 3
MasterLiquid ML240L V2 RGB image number 4
MasterLiquid ML240L V2 RGB image number 5
CoolerMaster MasterLiquid ML240L RGB V2 is a refreshed design from the popular MasterLiquid Lite Series that elevates the exterior design elements. The Pump of the ML240L RGB V2 has been enhanced with the newly designed 3rd Gen. Dual Chamber Pump that improves the overall cooling efficiency of the AIO water cooler. The radiator surface area has been enlarged to increase the surface area for heat dissipation for optimized cooling performance. The ML240L RGB V2 will included the latest SickleFlow 120 RGB fan with a brand new design and Air Balance fan blades that is quieter than before without compromising on air flow and pressure.
