MasterLiquid ML240 RGB TR4 Edition image number 0
MasterLiquid ML240 RGB TR4 Edition image number 1
MasterLiquid ML240 RGB TR4 Edition image number 2
MasterLiquid ML240 RGB TR4 Edition image number 3
MasterLiquid ML240 RGB TR4 Edition image number 4
MasterLiquid ML240 RGB TR4 Edition image number 5
MasterLiquid ML240 RGB TR4 Edition image number 6
MasterLiquid ML240 RGB TR4 Edition image number 7
MasterLiquid ML240 RGB TR4 Edition image number 8
MasterLiquid ML240 RGB TR4 Edition image number 9
MasterLiquid ML240 RGB TR4 Edition image number 10
MasterLiquid ML240 RGB TR4 Edition image number 11
MasterLiquid ML240 RGB TR4 Edition image number 12
MasterLiquid ML240 RGB TR4 Edition image number 13
MasterLiquid ML240 RGB TR4 Edition image number 14
A New Way To Flow
The MasterLiquidML240 RGB TR4 Edition all-in-one liquid CPU cooler is custom, inside and out.
  • Radiator Material Aluminum
  • Pump Rated Voltage 12 VDC
  • Pump MTTF 70,000 Hours
  • Fan Quantity 2 PCS
  • Pump Connector 3-Pin
  • Cooler Type Liquid Cooler
  • Fan MTTF 160,000 Hours
  • Pump Noise Level < 15 dBA
  • Radiator Size 240
  • Fan Speed 650-2000 RPM (PWM) ± 10%
  • Pump Dimensions 86 x 70 x 49 mm / 3.4 x 2.8 x 1.9 inch
  • Fan Air Pressure 2.34 mmH2O (Max)
  • Series MasterLiquid
  • CPU Socket TR4
  • Dimensions (L x W x H) 277 x 119.6 x 27mm / 10.9 x 4.7 x 1.1 inch
  • Fan Airflow 66.7 CFM (Max)
  • Product Number MLX-D24M-A20PC-T1
