MasterLiquid ML120R RGB image number 0
MasterLiquid ML120R RGB image number 1
MasterLiquid ML120R RGB image number 2
MasterLiquid ML120R RGB image number 3
MasterLiquid ML120R RGB image number 4
MasterLiquid ML120R RGB image number 5
MasterLiquid ML120R RGB image number 6
The Most Colorful Way To Cool
The MasterLiquid ML120R RGB all-in-one liquid CPU cooler is custom, inside and out.
  • Pump Dimensions 83.6 x 71.8 x 52.7 mm / 3.3 x 2.8 x 2.1 inch
  • Pump MTTF 70,000 Hours
  • Radiator Material Aluminum
  • Pump Rated Voltage 12 VDC
  • Fan Quantity 2 PCS
  • Radiator Dimensions 157 x 119.6 x 27 mm / 6.2 x 4.7 x 1.1 inch
  • Cooler Type Liquid Cooler
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Fan MTTF 160,000 Hours
  • Pump Noise Level < 15 dBA
  • Power Connector 3-Pin
  • Fan Speed 650-2000 RPM (PWM) ± 10%
  • Radiator Size 120
  • CPU Socket LGA1700
  • Fan Air Pressure 2.34 mmH2O (Max)
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Series MasterLiquid
  • CPU Socket AM5
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Note For LGA 1700 mounting kits, You may obtain through the CM store, regional resellers and distributors. It's compatible with AMD AM5 although the package may not stress it.
  • Product Number MLX-D12M-A20PC-R1
  • Fan Airflow 66.7 CFM (Max)
