MasterLiquid ML120L RGB image number 0
MasterLiquid ML120L RGB image number 1
MasterLiquid ML120L RGB image number 2
MasterLiquid ML120L RGB image number 3
MasterLiquid ML120L RGB image number 4
MasterLiquid ML120L RGB image number 5
MasterLiquid ML120L RGB image number 6
MasterLiquid ML120L RGB image number 7
MasterLiquid ML120L RGB image number 8
Silence. Performance. All-in-One.
MasterLiquid ML120L RGB is a Cooler Master original design and enables a colorful entry into liquid cooling.
  • Radiator Material Aluminum
  • Pump Rated Voltage 12 VDC
  • Pump MTTF 70,000 Hours
  • Pump Connector 3-Pin
  • Cooler Type Liquid Cooler
  • CPU Socket LGA2066
  • Radiator Dimensions 157 x 119.6 x 27 mm / 6.2 x 4.7 x 1.1 inch
  • Pump Dimensions 80.3 x 76 x 42.2 mm / 3.2 x 3.0 x 1.7 inch
  • CPU Socket LGA2011-v3
  • Fan MTTF 160,000 Hours
  • Pump Noise Level < 15 dBA
  • Fan Speed 650-2000 RPM (PWM) ± 10%
  • Radiator Size 120
  • Fan Air Pressure 2.34 mmH2O (Max)
  • CPU Socket LGA1366
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • Series MasterLiquid Lite
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Product Number MLW-D12M-A20PC-R1
  • Fan Airflow 66.7 CFM (Max)
