MasterLiquid Core Nex Series image number 0
MasterLiquid Core Nex Series image number 1
MasterLiquid Core Nex Series image number 2
MasterLiquid Core Nex Series image number 3
360 Degrees of Cool​
Dual Chamber Pump​
Innovative Design​
Flexible Pump Orientation​
Easy Installation​
Universal Socket Support​
Optimum Tubing Length
Innovative Design
An infinity mirror pump cover design brings stylish lighting and a modern touch to your build​
Featuring a rotatable pump cover that allows users to customize the orientation for the perfect look.
Dual chamber pump
Patented design
Improved Quality
Dual Chamber Pump
Our patented dual chamber design delivers a compact cooler with efficient and reliable performance.
400 mm tubing allows for effortless cooler installation in any orientation.
Easy Installation
Easy Installation
With pre-installed fans, streamlined cabling, pre-applied thermal paste, and pre-mounted brackets, setup is quick, clean, and effortless
Broad compatibility with both Intel and AMD CPU sockets
Pre-Applied CryoFuze Thermal Paste
Tube Clips Included
  • Product Name MasterLiquid Core Nex Series
  • Product Number 240 Black: MLX-D24M-A18PA-R1
  • Product Number 240 White: MLX-D24M-A18PA-RW
  • Product Number 360 Black: MLX-D36M-A18PA-R1
  • Product Number 360 White: MLX-D36M-A18PA-RW
  • CPU Socket Intel® LGA 1851 / 1700 / 1200 / 1150 / 1151 / 1155 / 1156
  • CPU Socket AMD® AM5 / AM4
  • Radiator Material Aluminum
  • Radiator Dimensions 240: 277 x 119.6 x 27.2 mm (10.9 x 4.71 x 1.1 inch)
  • Radiator Dimensions 360: 394 x 119.6 x 27.2 mm (15.5 x 4.7 x 1.1 inch)
  • Pump Dimensions 83.6 x 78.5 x 62.9 mm​ (3.3 x 3.1 x 2.5 inch)
  • Pump Profiles Addressable RGB
  • Pump Speed 2800 ±10% RPM
  • Pump MTTF >35,000 Hours
  • Pump Rated Voltage 12 VDC
  • Fan Power Consumption 7.2 W
  • Tube Length 400 mm
  • Fan Dimensions (L x W x H) 120 x 120 x 25 mm ​ (4.7 x 4.7 x 1 inch)
  • Fan LED Addressable RGB
  • Fan Quantity 240: 2 PCS
  • Fan Quantity 360: 3 PCS
  • Fan Speed 650 ~ 1750 RPM ±10%
  • Fan Airflow 122.4 m³/h (71.9 CFM) (Max)
  • Fan MTTF >40,000 Hours
  • Fan Rated Current 0.26 A
  • Fan Safety Current 0.37 A
  • Fan Power Consumption 3.12W
  • Warranty 5 years
