New
Cooling, Displayed Your Way
MasterLiquid Core LCD 360 4-inch
4-inch High-Resolution LCD
Rotatable Display Base
Dual-Chamber Pump Design
Three-Phase Motor
High-Temperature Resistant Sealing
Performance builds today do more than push frames. They reflect how you build, what you run, and how you want your system to look. The MasterLiquid Core LCD Series brings cooling and customization together with a 4-inch display that gives your system a clear point of focus.
Under the hood, a redesigned dual-chamber pump improves heat transfer while keeping noise under control. Paired with a three-phase motor, it runs smoothly and consistently, even when your system is under sustained load.
The 4-inch LCD adds a new layer of control without adding complexity. Rotate it to match your build, then customize what you see with system stats, images, or video. Backed by durable materials and reinforced sealing, it’s built to run reliably over time.
A 4-inch, 480 × 480 LCD display designed to be clearly visible inside modern PC builds. Display real-time system stats, custom images, or video, and adjust it to match your setup with simple, intuitive controls.
Multi-format custom screen background
Supports JPG format, GIF animations, and MP4 videos, offering a wide range of options.
Real‑time monitoring of computer operating status
All computer operating parameters are clearly displayed, helping to ensure safe and stable device operation.
360° adjustable base
The patented rotatable base allows 360-degree adjustment, so the screen stays properly oriented regardless of how the cooler is installed. However your system is configured, your display stays aligned.
Newly optimized pump design
Thermal dissipation performance of the previous-generation process
*Data source: Cooler Master Testing Lab
A redesigned dual-chamber pump improves coolant flow and focuses cooling directly on the CPU hot spot. The result is more efficient heat transfer with smoother, quieter operation under load.
Core Upgrades
Three-phase Motor
A three-phase motor keeps the pump running smoothly and consistently, reducing vibration and supporting low-noise performance during sustained use.
Ceramic Impeller
Does not easily deform under high-temperature
conditions and has strong tolerance to additives
and metal ions
Durable materials, high-temperature resistant sealing, and automotive-grade coolant are designed to support long-term reliability and help reduce the risk of leakage over time.
High Performance Fan Upgrade
The MasterLiquid Core LCD 360 (4-inch) features a 4-inch high-resolution display and upgraded fans rated for 2800 RPM. Designed for thermal loads up to 300W, it delivers reliable cooling for high-performance systems. Pre-attached fan cables reduce setup time with fewer power and ARGB connections.
