MasterLiquid Core LCD 360 4-inch image number 0
MasterLiquid Core LCD 360 4-inch image number 1
MasterLiquid Core LCD 360 4-inch image number 2
MasterLiquid Core LCD 360 4-inch image number 3
MasterLiquid Core LCD 360 4-inch image number 4
Cooling, Displayed Your Way
4-inch High-Resolution LCD
Rotatable Display Base
Dual-Chamber Pump Design
Three-Phase Motor
High-Temperature Resistant Sealing
A 4-inch, 480 × 480 LCD display designed to be clearly visible inside modern PC builds. Display real-time system stats, custom images, or video, and adjust it to match your setup with simple, intuitive controls.
Multi-format custom screen background
Supports JPG format, GIF animations, and MP4 videos, offering a wide range of options.
Real‑time monitoring of computer operating status
All computer operating parameters are clearly displayed, helping to ensure safe and stable device operation.
360° adjustable base
The patented rotatable base allows 360-degree adjustment, so the screen stays properly oriented regardless of how the cooler is installed. However your system is configured, your display stays aligned.
Newly optimized pump design
Thermal dissipation performance of the previous-generation process
*Data source: Cooler Master Testing Lab
A redesigned dual-chamber pump improves coolant flow and focuses cooling directly on the CPU hot spot. The result is more efficient heat transfer with smoother, quieter operation under load.
Core Upgrades
Three-phase Motor
A three-phase motor keeps the pump running smoothly and consistently, reducing vibration and supporting low-noise performance during sustained use.
Ceramic Impeller
Does not easily deform under high-temperature
conditions and has strong tolerance to additives
and metal ions
Durable materials, high-temperature resistant sealing, and automotive-grade coolant are designed to support long-term reliability and help reduce the risk of leakage over time.
High Performance Fan Upgrade
  • Product Number 360 Black: MLX-D36M-A18PA-RL
  • Product Number 360 White: MLX-D36M-A18PW-RL
  • CPU Socket Intel® LGA 1851 / 1700 / 1200 / 1150 / 1151 / 1155 / 1156
  • CPU Socket AMD® AM5 / AM4
  • Radiator Material Aluminum
  • Radiator Dimensions 360: 394 x 119.6 x 27.2 mm (15.5 x 4.7 x 1.1 inch)
  • Pump Profiles Addressable RGB
  • Pump Speed 2800 ±10% RPM
  • Pump Rated Voltage 12 VDC
  • Fan Power Consumption 7.2 W
  • Tube Length 400 mm
  • Fan Dimensions (L x W x H) 120 x 120 x 25 mm ​ (4.7 x 4.7 x 1 inch)
  • Fan LED Addressable RGB
  • Fan Quantity 360: 3 PCS
  • Fan Speed 650 ~ 1750 RPM ±10%
  • Fan Airflow 122.4 m³/h (71.9 CFM) (Max)
  • Fan MTTF >40,000 Hours
  • Fan Rated Current 0.26 A
  • Fan Safety Current 0.37 A
  • Fan Power Consumption 3.12W
  • Warranty 5 years
