MasterLiquid ATMOS Stealth Series image number 0
MasterLiquid ATMOS Stealth Series image number 1
MasterLiquid ATMOS Stealth Series image number 2
MasterLiquid ATMOS Stealth Series image number 3
360 Degrees of Cool
Exceptional silence
Optimized user experience
Fully customizable
Eco-friendly construction
Refined dual chamber design
The pump cover is manufactured from eco friendly recycled plastics
and features a transparent, removable top cover that allows you to
customize it with your own logo or badge. This version of the ATMOS is also an all blackout, non LED release, allowing for a super stealthy
aesthetic. Cooler Master is leaping into the future with the ATMOS
series.
Design
Fully customizable
Customize the pump top cover with your 3D designs and take full control of the ARGB Gen 2 lighting. The Atmos provides unprecented creative freedom.
Cooling System
DUAL CHAMBER DESIGN
DUAL CHAMBER DESIGN
Patented design
DUAL CHAMBER DESIGN
Improved Quality
Gadget
TUBE CLIPS INCLUDED
Tube clips are made for AIO tube size that not only to improve and strengthen your cooler setup,but also can fix your ARGB or PWM cables.
Gadget
THERMAL PASTE
APPLICATION STICKER
Materials
The pump top cover has been constructed from recycled plastic materials, while 35% of the cooler's metal materials are recycable. Along with sustainable packaging materials and a 30% reduction in total packaging size, the Atmos is an eco-pioneer.
Fans
MOBIUS 120 BLACK FANS
Pre-installed Mobius 120mm black fans further improve cooling performance and simplify user installation.
Our Achievements
8 awards
  • Product Number MLX-D36M-A24PK-R1 (MasterLiquid 360 ATMOS Stealth)
  • Product Number MLX-D24M-A24PK-R1 (MasterLiquid 240 ATMOS Stealth)
  • Exterior Color Black
  • CPU Socket Intel® LGA 1851 / 1700 / 1200 / 1156 / 1155 / 1151 / 1150 Socket
  • Radiator Material Aluminum
  • Radiator Dimensions 394 x 119.2 x 27.2 mm / 15.5 x 4.7 x 1.1 inch (MasterLiquid 360 ATMOS Stealth)
  • Radiator Dimensions 277 x 119.2 x 27.2 mm​ / 10.9 x 4.7 x 1.1 inch (MasterLiquid 240 ATMOS Stealth)
  • Pump Dimensions 84.9 x 81 x 53.15 mm 3.3 x 3.2 x 2.1 inch
  • Pump MTTF >210,000 Hours
  • Pump Speed 3400 ± 300 RPM
  • Fan Connector 4-Pin
  • Pump Rated Voltage 12 VDC
  • Fan Dimensions (L x W x H) 120 x 120 x 25 mm / 4.7 x 4.7 x 1 inch
  • Fan Quantity 3 PCS (MasterLiquid 360 ATMOS Stealth)
  • Fan Quantity 2 PCS (MasterLiquid 240 ATMOS Stealth)
  • Fan Speed 0-2400 RPM ± 10%
  • Airflow (max.) 127.6 m³/h (75.2 CFM)
  • Fan Noise Level 30 dBA
  • Fan MTTF >200,000 Hours
  • Fan Rated Current 0.18 A
  • Safety Current 0.35A
  • Fan Power Consumption 2.16 W
  • Warranty 5 years
  • Cooler Type Liquid Cooler
  • Series MasterLiquid
