MasterLiquid 360L Core ARGB White image number 0
MasterLiquid 360L Core ARGB White image number 1
Cooler Master is building upon the success of the MasterLiquid Lite Series with a redesigned and improved release of the MasterLiquid 360L Core White
Buy Now
CLEAN
CLASSIC DESIGN
Clean minimalist design brings a refreshed modern facelift to the pump cover.
CRYOFUZE THERMAL PASTE
Includes premium CryoFuze thermal paste for exceptional heat conductivity.
Gen S Dual Chamber Pump
Redesigned copper base targets heat spots with precision along with boosted water flow and pressure for enhanced cooling performance.
Expanded Radiator Surface
120mm ARGB Fans
Upgraded 120mm ARGB fans deliver optimal radiator performance and versatile lighting options.
CPU COMPATIBILITY
CPU COMPATIBILITY
Learn More
  • Product Number MLW-D36M-A18PZ-RW
  • Exterior Color White
  • CPU Socket AMD® AM5 / AM4 / AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 socket
  • Radiator Material Aluminum
  • Radiator Dimensions 394 x 119.6 x 27.2 mm / 15.5 x 4.7 x 1.1 inch
  • Pump Dimensions 81 x 76 x 47 mm / 3.2 x 3 x 1.9 inch
  • Pump MTTF >70,000 Hours
  • Pump Noise Level 12 dBA (Max)
  • Pump Rated Voltage 12 VDC
  • Pump Power Consumption 3.96W
  • Fan Quantity 3 PCS
  • Fan LED Type ARGB
  • Fan Speed 650-1750 RPM ± 10%
  • Fan Airflow 71.93 CFM (Max)
  • Fan Pressure 1.86 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.26A
  • Fan Safety Current 0.37A
  • Pump Connector 3-Pin
  • Warranty 3 years
  • Cooler Type Liquid Cooler
  • Series MasterLiquid Lite
  • Radiator Size 360
