MasterLiquid 240 image number 0
MasterLiquid 240 image number 1
MasterLiquid 240 image number 2
MasterLiquid 240 image number 3
MasterLiquid 240 image number 4
MasterLiquid 240 image number 5
MasterLiquid 240 image number 6
MasterLiquid 240 image number 7
MasterLiquid 240 image number 8
MasterLiquid 240
MasterLiquid 240
MasterLiquid 240
MasterLiquid 240
MasterLiquid 240
MasterLiquid 240
MasterLiquid 240
MasterLiquid 240
MasterLiquid 240
A New Way to Flow
MasterLiquid 240
The MasterLiquid 240 all-in-one liquid CPU cooler is custom, inside and out.
  • Radiator Material Aluminum
  • Pump Rated Voltage 12 VDC
  • Pump MTTF 70,000 Hours
  • Fan L-10 Life 22,800 Hours
  • Legacy Cooling
  • Pump Dimensions 85.6 x 70 x 49 mm / 3.37 x 2.76 x 1.93 inch
  • Pump L-10 Life 20,000 Hours
  • Fan Quantity 2 PCS
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Radiator Size 240
  • Fan MTTF 160,000 Hours
  • Radiator Dimensions 277 x 119.6 x 27 mm / 10.9 x 4.71 x 1.06 inch
  • Fan Speed 650-2000 RPM (PWM) ± 10%
  • Pump Noise Level 15 dBA (Max)
  • CPU Socket LGA1366
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • CPU Socket AM5
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Note For LGA 1700 mounting kits, You may obtain through the CM store, regional resellers and distributors. It's compatible with AMD AM5 although the package may not stress it.
  • Product Number MLX-D24M-A20PW-R1
  • Fan Airflow 66.7 CFM (Max)
  • Fan Air Pressure 2.34 mmH2O ± 10% (Max)
