A New Way to Flow
MasterLiquid 120
MasterLiquid 120
Fan Rated Voltage12 VDC
Radiator MaterialAluminum
Pump Rated Voltage12 VDC
Pump MTTF70,000 Hours
Fan L-10 Life22,800 Hours
Pump Dimensions85.6 x 70 x 49 mm / 3.37 x 2.76 x 1.93 inch
Fan Quantity2 PCS
Cooler TypeLiquid Cooler
Warranty2 years
CPU SocketLGA2066
Pump L-10 Life20,000 Hours
Radiator Dimensions157 x 119.6 x 27 mm / 6.2 x 4.7 x 1.1 inch
CPU SocketLGA2011-v3
Fan MTTF160,000 Hours
Fan Speed650-2000 RPM (PWM) ± 10%
CPU SocketLGA2011
Radiator Size120
Fan Air Pressure2.34 mmH2O (Max)
Pump Noise Level15 dBA (Max)
CPU SocketLGA1366
CPU SocketLGA1200
CPU SocketLGA1156
CPU SocketLGA1155
CPU SocketLGA1151
CPU SocketLGA1150
SeriesMasterLiquid
CPU SocketLGA775
CPU SocketAM5
CPU SocketAM4
CPU SocketAM3+
CPU SocketAM3
CPU SocketAM2+
CPU SocketAM2
CPU SocketFM2+
CPU SocketFM2
CPU SocketFM1
NoteFor LGA 1700 mounting kits, You may obtain through the CM store, regional resellers and distributors. It's compatible with AMD AM5 although the package may not stress it.
Product NumberMLX-D12M-A20PW-R1
Fan Airflow66.7 CFM (Max)
