MasterKeys Pro M RGB Mechanical Gaming Keyboard image number 0
MasterKeys Pro M RGB Mechanical Gaming Keyboard image number 1
MasterKeys Pro M RGB Mechanical Gaming Keyboard image number 2
MasterKeys Pro M RGB Mechanical Gaming Keyboard image number 3
Built for Pros, Not Joes
With the MasterKeys Pro M, you get the best of both worlds; the brightest LEDs and the best tactile feeling that gamers have come to love.
  • Product Keyboard
  • Keyboard Repeat Rate 1x
  • Keyboard Type Mechanical
  • Cable Detachable with Micro-USB
  • Cable Length 1.5m / 59.05 inch
  • Keyboard Switch Type Cherry MX
  • On-the-fly System Macro Record
  • Keyboard Material Plastic
  • Keyboard LED Color RGB
  • AP support GUI supports
  • Keyboard Response Rate 1ms
  • Smart Cable Manager With 3 ways
  • Keyboard Material Metal
  • On-the-fly System Lighting Control
  • On-board Memory 512KB
  • Serie MasterKeys Pro
  • Keyboard Repeat Rate 2x
  • Keyboard Repeat Rate 4x
  • Keyboard Switch Type Cherry MX Blue
  • Wrist rest N/A
  • Keyboard Switch Type Cherry MX Brown
  • Keyboard Repeat Rate 8x
  • Keyboard Switch Type Cherry MX Red
  • Product Name MasterKeys Pro M RGB
  • Keyboard Switch Type Cherry MX Silver
  • Weight 1025g
  • Connector Cable USB 2.0 with Braided
  • Dimensions (L x W x H) 377 x 141 x 38 mm
  • EAN Code 4719512055113 (Blue switch US)
  • UPC Code 884102030581 (Blue switch US)
  • UPC Code 884102030598 (Brown Switch US)
  • EAN Code 4719512055274 (Brown Switch US)
  • EAN Code 4719512054963 (Red Switch US)
  • UPC Code 884102030574 (Red Switch US)
  • UPC Code 884102031151 (Silver Switch US)
  • EAN Code 4719512057995 (Silver Switch US)
  • Product Number SGK-6040-KKCL1
  • Product Number SGK-6040-KKCM1
  • Product Number SGK-6040-KKCR1
  • Product Number SGK-6040-KKCS1
