MasterKeys Lite L image number 0
MasterKeys Lite L image number 1
MasterKeys Lite L image number 2
MasterKeys Lite L image number 3
MasterKeys Lite L
MasterKeys Lite L
MasterKeys Lite L
MasterKeys Lite L
Switch up Your Game
MasterKeys Lite L
The MasterKeys Lite L with RGB gives you gaming keyboard with incredible features. Equipped with brilliant zoned RGB lighting for you to customize...
  • Keyboard Type Mechanical
  • LED Color RGB
  • Color Black
  • Product Keyboard
  • Switch Type Cooler Master Mem-chanical
  • Repeat Rate Normal 1x / Turbo 8x
  • On-the-fly System Lighting Control
  • Connector Cable USB 2.0
  • Cable Length 1.8m
  • Serie MasterKeys Lite
  • On-the-fly System Win Lk
  • Cable Non-Detachable Rubber Cable
  • On-the-fly System Multimedia
  • On-the-fly System Full Keys LK
  • Dimensions (L x W x H) 439 x 129 x 41 mm / 17.28 x 5.12 x 1.61 inch
  • Product Name MasterKeys Lite L
  • Weight 967g
  • EAN Code 4719512055571 (US Layout)
  • UPC Code 884102030659 (US Layout)
  • Product Number SGK-3040-KKMF1-US
