MasterKeys Lite L Combo RGB image number 0
MasterKeys Lite L Combo RGB image number 1
MasterKeys Lite L Combo RGB image number 2
MasterKeys Lite L Combo RGB image number 3
MasterKeys Lite L Combo RGB image number 4
MasterKeys Lite L Combo RGB image number 5
MasterKeys Lite L Combo RGB image number 6
MasterKeys Lite L Combo RGB image number 7
MasterKeys Lite L Combo RGB image number 8
Switch up Your Game
The MasterKeys Lite L Combo with RGB gives you two gaming devices with incredible features. Equipped with brilliant zoned RGB lighting for you...
  • Keyboard Type Mechanical
  • Mouse Cable Length 1.8m / 70.9 in
  • Mouse Connector Cable USB 2.0
  • Mouse LED Color RGB
  • Mouse Color Black
  • Mouse On-the-fly system Lighting Control
  • Mouse Cable Non-Detachable Rubber Cable
  • Mouse Warranty 2 years
  • Keyboard LED Color RGB
  • Keyboard Cable Non-Detachable Rubber Cable
  • Keyboard Cable Length 1.8 Meters
  • Keyboard Warranty 2 years
  • Keyboard Weight 967g (without Cable)
  • Mouse On-the-fly system DPI Settings
  • Mouse Weight 91g
  • Mouse Dimensions 114 x 64 x 39 mm (L x W x H)
  • On-the-fly System Lighting Control
  • Mouse Switch Type Omron 10M
  • Product Keyboard Mouse Combos
  • Serie MasterKeys Lite
  • Keyboard Connector Cable USB 2.0
  • Keyboard Dimensions (L x W x H) 439 x 129 x 41 mm
  • On-the-fly System Win Lk
  • Mouse Sensor Optical Avago 3050
  • Keyboard Repeat Rate Normal 1x / Turbo 8x
  • On-the-fly System Multimedia
  • On-the-fly System Full Keys LK
  • Product Name MasterKeys Lite L Combo RGB
  • Keyboard Switch Type Cooler Master Mem-chanical
  • EAN Code 4719512052754 (US Layout)
  • UPC Code 884102028861 (US Layout)
  • Product Number SGB-3040-KKMF1-US
