Global Headquarters
Premium modular ATX case
Premium open-frame ATX case designed for modular builds, extreme cooling, and total customization through the FreeForm 2.0 platform.
The exposed frame structure enhances chassis adaptability and provides flexible configuration options for various scenarios.
Its open source design and interchangeable panels offer endless personalization possibilities, transforming your chassis into a unique expression of style.
Supports Mini-ITX to E-ATX motherboards, offering compatibility with a wide range of builds and configurations.
Can house up to eight fans and multiple radiator sizes (up to 360mm), ensuring superior thermal performance.
Accommodates graphics cards up to 390mm, offering plenty of space for high-end GPUs.
Easily remove side panels and other components without tools for quick access and modifications during build or upgrades.
The included GPU support bracket prevents GPU sag and ensures stability during intense gaming or high-performance workloads, maintaining a clean and secure build.
