TOOL-FREE PANEL REMOVAL
Easily remove side panels without tools for quick access and modifications during build or upgrades.
Compact Power, No Compromise.
Premium open-frame Micro-ATX case designed for compact performance builds, efficient airflow, and refined structural design inspired by the FreeForm 2.0 platform.
The MasterFrame 400 Mesh is a premium open-frame compact chassis crafted for Micro-ATX and Mini-ITX platforms. Embracing the FreeForm 2.0 design philosophy, it features a precision aluminum frame, dual-orientation support, and enhanced mesh airflow. With premium aesthetics and performance-grade clearance, it empowers creators and builders to push compact PC design further.
The exposed aluminum frame supports versatile positioning and adapts seamlessly to both vertical and horizontal layouts.
Stand it tall, lay it flat, or flip it sideways. Detachable feet and a smart, adaptable design make it easy to fit any workspace or creative setup.
*Vertical orientation may require additional accessories or adapters depending on component layout, connector clearance, or cable routing.
Supports Mini-ITX and Micro-ATX motherboards, delivering optimal compatibility for compact, high-performance builds without compromising cooling or component clearance.
Accommodates graphics cards up to 390mm in length, providing full compatibility for high-end GPUs and future upgrades.
Supports up to nine fans, including 200 mm fans compatibility, plus top-mounted 360 mm radiators for superior airflow in a compact build.
*200 mm fan support varies by location and fan thickness.
The included GPU support bracket prevents GPU sag and ensures stability during intense gaming or high-performance workloads, maintaining a clean and secure build.
Stay connected and ready for anything—MasterFrame 400 Mesh features USB 3.2 Gen 2x2 Type-C, dual USB 3.2 Gen 1 Type-A, and a combo audio jack for ultra-fast data, charging, and seamless peripheral support.
Despite its compact size, the MasterFrame 400 Mesh comes alive with a pre-installed 120 mm SickleFlow ARGB fan—quiet, powerful, and fully customizable.
