New
Limited edition
MasterFrame 360 Panorama S Limited Edition
Pre-order the MasterFrame 360 Panorama S Limited Edition full system now.
See full specs
Pre-order Price: USD $3,099.99 (was $3,599.99 ) – Free Delivery
Shipping Update:
Your order is currently on its way to your address.
For updates or assistance, please feel free to contact our D2C support team through our official website or other authorized channels.
(Shipping outside the US or EU?
Please [click here] to place your order through the regional site.)
Turn your rig into a Stage.
The front display stage transforms your PC into a personal showcase - perfect for collectibles, figures, and decorations that reflect your style.
Designed to Showcase. Built to Inspire.
Designed to spotlight your hardware, collectibles, and creativity - MasterFrame 360 Panorama provides a platform to transform your gaming rig into a personal showcase.
Vision Image
Hidden Image
Crystal Clear Design.
Show every detail that defines your build, from powerful hardware to your unique style, all in plain view.
From Vision to Reality.
The MasterFrame 360 Panorama showcases Cooler Master’s dedication to personalized expression. The concept was built on the original MasterFrame’s aluminum chassis modular design and further developed in collaboration with acclaimed PC modder “AK Mod” during COMPUTEX 2025. It underwent additional refinement through Cooler Master’s research and development team, ultimately leading to mass production.
The result is the MasterFrame 360 Panorama you see today.
What makes the MasterFrame 360 Panorama stand out.
Front Display Stage
Front display stage to showcase collectibles and add personal style to your limited edition rig.
Extreme Cooling Flexibility
Supports up to 12×120 mm, 4×140 mm, 4×180 mm, and 4×200 mm fans, or up to 4×360 mm radiators for ultimate thermal performance.
Wide Motherboard Compatibility
Supports Mini-ITX, Micro-ATX, ATX, and BTF with 110 mm cable clearance for clean, sleek setups.
Vertical GPU Support
Pre-installed PCIe 5.0 riser cable enables vertical GPU mounting, ensuring full accessibility of GPU aesthetics.
Priority Shipping & Early Access
Pre-order the exclusive MasterFrame 360 Panorama S Limited Edition - a prebuilt system with selected components, available only during this limited pre-order. It comes with the signature features of the iconic MasterFrame 360 Panorama Craft Edition case.
One of 100
Each unit features an individually numbered, laser-etched stainless steel nameplate for ultimate exclusivity.
Built for Performance
Dual-Chamber Layout
Keeps hardware and cables separated for a cleaner build.
Simplified I/O Panel
Essential ports with a minimal, streamlined design for easy access.
Dual ARGB Spotlights
Mounted on the front display stage to illuminate your collectibles with vivid ARGB lighting.
Pre-installed Nvidia Geforce RTX™ 5080 GPU
Powered by NVIDIA’s latest architecture, featuring fifth-gen Tensor Cores for advanced AI with FP4 and DLSS 4, fourth-gen Ray Tracing Cores for mega geometry, and new streaming multiprocessors tuned for neural shaders.
Pre-installed 12×120mm ARGB Fans
Comes with twelve 120mm ARGB fans, including SickleFlow Edge and Reverse Blade modules—pre-arranged for balanced airflow and synchronized lighting.
MasterLiquid Atmos II 360 LCD AIO Cooler
Features real-time status display on the pump cover and a patented dual-chamber pump design for improved cooling and reliability.
CPU: AMD 9800X3D
Motherboard: MSI MAG B850 TOMAHAWK MAX WIFI
Memory: DDR5 RGB 6000 32GB(16GBx2)
M.2 SSD: Kingston NV3 2TB M.2 2280 NVMe SSD
GPU: Nvidia Geforce RTX™ 5080 GPU
PSU: Cooler Master V Platinum 1100 V2
Thermal: Cooler Master MasterLiquid Atmos II 360 LCD
Case: Cooler Master MasterFrame 360 Panorama Craft Edition
Windows OS: Comes Pre-installed with Windows 11 Home
Disclaimer
* Figures, models, or other display items are for demonstration purposes only and are not included in the product for sale.
** Product specifications are subject to change. Final configuration is determined by the specifications confirmed at time of order. All visuals are for illustration only and may differ from the actual product.
Warranty Information
To ensure peace of mind, warranty coverage is provided for each component as follows:
Motherboard / CPU
Due to the component manufacturers’ warranty policy, RMA requests must typically be processed with assistance from your local Cooler Master representative. However, this does not affect your statutory rights. Within the legal warranty period, you may also request support directly from your place of purchase.
DRAM / M.2 SSD
Global warranty is provided by the component manufacturers.
Cooler Master Components (Case / PSU / Thermal / Custom GPU)
Covered under Cooler Master’s local warranty, in accordance with local consumer law.
Important Notice Europe (EEA Customers)
This warranty is provided in addition to, and does not affect, your statutory rights under the applicable consumer protection laws in your country of purchase. In the European Economic Area (EEA), consumers are entitled to a 2-year legal warranty from the date of purchase. Any claims need to be made through the seller.
Terms & Conditions
