MasterFan SF360R ARGB image number 0
MasterFan SF360R ARGB image number 1
MasterFan SF360R ARGB image number 2
MasterFan SF360R ARGB image number 3
MasterFan SF360R ARGB image number 4
MasterFan SF360R ARGB image number 5
Blow Away The Competition
MasterFan SF360R ARGB, CoolerMaster's very first 360mm Addressable RGB fan, provides a specific air cooling solution ideal for your coolers
  • RGB Rated Voltage 5 VDC
  • LED Lighting ARGB
  • Fan Size 360
  • RGB Connector 3-Pin ARGB
  • Cooler Type Case Fan
  • Fan MTTF 160,000 Hours
  • Fan Bearing Type LDB
  • Number of LEDs 8pcs x 3
  • Fan Safety Current 0.54A
  • Fan Safety Current 0.6A
  • Fan Noise Level 8 - 30 dBA
  • RGB Rated Current 1.2A
  • Series MasterFan
  • Fan Dimensions (L x W x H) 360 x 120 x 25 mm / 14.2 x 4.7 x 1 inch
  • Fan Weight 378g / 0.83lbs
  • Fan Power Consumption 6.48W
  • Fan Air Pressure 1.58 mmH2O ± 10%
  • Fan Speed 650-1800 RPM ± 10%
  • Fan Airflow 43 x 3 CFM ± 10%
  • Product Number MFX-B2D3-18NPA-R1
