MasterFan SF120R RGB image number 0
MasterFan SF120R RGB image number 1
MasterFan SF120R RGB image number 2
MasterFan SF120R RGB image number 3
MasterFan SF120R RGB image number 4
Square Is The New Cool
MasterFan SF120R RGB, a new member of the MasterFan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans.
  • Fan Profiles RGB
  • LED Lighting RGB
  • RGB Rated Voltage 12 VDC
  • RGB Rated Current 0.2A
  • Fan Bearing Type LDB
  • RGB Connector 4-Pin RGB
  • Fan MTTF 160,000 Hours
  • Cooler Type Case Fan
  • Fan Speed 650-2000 RPM (PWM) ± 10%
  • Fan Safety Current 0.37A
  • Fan Size 120
  • Fan Noise Level 8 - 30 dBA
  • Fan Power Consumption 1.92W
  • Fan Rated Current 0.16A
  • Series MasterFan
  • Fan Weight 191g / 0.42lb
  • Fan Airflow 59 CFM ± 10%
  • Fan Air Pressure 2.1 mmH20 ± 10%
  • Product Number MFX-B2DN-20NPC-R1
