Select Your Silence
MasterFan Pro 140 Air Flow
Fan Rated Voltage12 VDC
Accessory4x Tap Screw
Fan Power Connector4-Pin (PWM)
Cooler TypeCase Fan
Warranty5 years
Fan Size140
Fan Power Consumption0.84W - S Mode (Silent)
LED LightingNon-LED
LEDNon-LED
Fan Life Expectancy490,000 Hours
Fan Power Consumption1.8W - Q Mode (Quiet)
Fan Dimensions (L x W x H)140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
SeriesMasterFan Pro
Fan Power Consumption3W - P Mode (Performance)
Fan Weight162g
Fan Rated Current0.15A - Q Mode (Quiet)
Fan Rated Current0.25A - P Mode (Performance)
Fan Rated Current0.07A - S Mode (Silent)
EAN code4719512052594
UPC code884102028700
Fan Noise Level6-20 dBA - S Mode (Silent)
Fan Noise Level6-30 dBA - Q Mode (Quiet)
Fan Noise Level6-36 dBA - P Mode (Performance)
Product NumberMFY-F4NN-08NMK-R1
Fan Speed650-800 RPM ± 10% - S Mode (Silent)
Fan Air Pressure0.54 mmH2O ± 10% - S Mode (Silent)
Fan Air Pressure1.42 mmH2O ± 10% - Q Mode (Quiet)
Fan Speed650-1300 RPM ± 10% - Q Mode (Quiet)
Fan Speed650-1600 RPM ± 10% - P Mode (Performance)
Fan Air Pressure2.1 mmH2O ± 10% - P Mode (Performance)
Fan Airflow53 CFM ± 10% - S Mode (Silent)
Fan Airflow88.1 CFM ± 10% - Q Mode (Quiet)
Fan Airflow106 CFM ± 10% - P Mode (Performance)
